I just got bumper tapped =( (Chipped paint, but no dent)
Je t'aime...
So recently my TSX got bumper tapped at my schools parking lot. I left at least 4 feet of room behind me and someone still crosses the line and hits my car. Grr... I didn't catch the guy or girl either to make things worst.
So I was wondering. How do I fix a bumper tap? Its like a small chipped paint I would say about 1/2 inch long? And less than a quarter of inch in width.
I'm not actually sure how to fix it. I know I would need to get touch up paint, but I heard I need to sand it down or something? Does anyone know the order of the process to do? Or has anyone done this before? Thanks for your help!
for small scrathes I use quixx 2 part scratch remover, for a larger chip on my bumper I just got while parked in NYC garage, I am going to try DrColorChip- I'll let you know how it works. OEM touch up paint is another great way, as mentioned by xts
Je t'aime...
This is a common procedure to cover up chips. Try to purchase the oem touch up paint. Apply at least 3 layers of touch up paint. Let the paint cure, then sand out the raised paint spots with a 1500 grit sandpaper followed by a 2000 grit sandpaper til the surface blends in.Then apply a rubbing compound followed by a wax to bring back the shine.
Why do I have to sand it with 1500 grit then 200 grit?
Also where can I get sandpaper? =)
Thanks.
Je t'aime...
Its not small scratches. Its more of a small chipped paint. The color of my paint on that area that's chipped its fully off. I think its down to the primer. I think...
Je t'aime...
Je t'aime...
Its not a mandatory step although he paint will stick better to the area if you do give it a quick sanding. You want to sand 1500 first to take out the raised paint edges quicker, then smooth out the area and the surrounding area with a higher grit sandpaper. The higher the grit on the sandpaper, the smoother the outcome of the sanding will be. I forgot to include the fact you need to wet sand. Soak your sandpaper in water for a few minutes. Then during the process, dip your sandpaper back in the water regularly to unclog the sandpaper and keeping it lubricated.
http://automotivetouchup.com/choosec...cura&model=Tsx
If you've never done touchup before just follow these instructions right on the same site
http://automotivetouchup.com/directions.htm
From what I hear they are pretty good.
Feeds pigs bacon
soupi
14
11-15-2015 11:15 AM
