Fluid Maintenance
Fluid Maintenance
Hey all! I DONT want to start an argument on who is right or wrong, but I just want some general info/experience on when you change your car fluids (which include engine oil, filter, power steering oil, differential oil, etc.)
I'm asking because my bro went to a shop with his 07 Murano (33xxx miles) and he ended up paying $320 for changing engine oil, power steering oil, and differential oil which were bad.
I change my engine oil every 5k miles but I haven't though about the other fluids. I have an 09 PMM TSX with 39xxx miles.
So it'd be great if you could list all the fluids you change (or plan to change) and at what mileage-mark you change them at.
I change my motor oil whenever the Maintenance Minder tells me to, usually every 5k-6k. Had my auto transmission fluid changed at 45k. Other than that, just windshield washer fluid... lol. Will be swapping my front+rear rotors/pads and changing out the brake fluid soon (55k), although it's because I personally want to, not because I have to.
Motor: 5-6K
Transmission: 45k
Brake: 55k
^^ thats about right. No power steering fluid change required though. Would hurt to look at your plugs also. I dont like the idea of leaving them in for 100k. I bought a civic that the owner never changed the plugs because of the 100k interval, anyways I changed them and what a difference. Cheap insurance to keep the car running smooth.
^ I completley agree, although that is a complete different subject from what the OP is asking (fluids) lol. I may be swapping my plugs sometime in the near future for some NGK plugs like I did in my old civic, it made a world of a difference!
CEB is here.
I know he'll agree with me.
first, everything is notated in your owners manual.
if you have questions about fluid intervals refer to the owners manual.
2nd: plugs. you will not notice any power difference changing the plugs early. after 100k miles the plugs will still have the same set gap.
There are a few things to consider. Where is the "cold" marking on the expansion tank in relationship to the actual cold level? Where is the "hot" level in relationship to hot coolant?
Where do you live? How low is it?
If you live in a temperate climate and only need to add a bit (say a cup or so) then distilled water is fine. If you need to add a substantial amount then you have a leak and need to have it checked.
The constant heating and cooling will cause a bit of evaporation and the current cold temps will lead to a bit more shrinkage (especially depending on when/where the car was PDI'd) so a bit of a drop this time of year is normal.
CEB is here.
I'd probably check plugs periodically. It isn't only the gaps but also a bit of wear or fouling that could diminish performance over time so gradually that you might not even notice - but yes, if all is well with the engine then the plugs won't wear.
CEB is here.
3G TL/2G MDX Owner
OP-
brake fluid every 3 years (per OM)
PS fluid as needed (no interval listed in OM)
coolant wait for the "5" usually with the 105k service (i have read it's the MID or 10 yrs).
tranny fluid wait for the "3"
oil...well i think you figured that one out pretty easy.
if you have your OM crack that open. if you don't and you registered your car with myacura, there is a digital copy in there for you to browse through.
OP-
SidhuSaaB
May 30, 2020 12:40 AM
acuratl26
Apr 23, 2020 07:30 PM
