DLC pin on the 09 tsx manual obd2 port
Does anyone has a picture of the DLC pin on the 09 tsx manual obd2 port?
I've search everywhere online, and I can't seem to find it,
I need it to help me figure out on the difference between the 09 tsx and 11 accord, so I can use flashpro on my accord,
thanks,
thanks,
ROTAREDOM
What is DLC pin?
Is that the orientation of the pins in the OBD II? I'm not really sure I understand what you're asking. OBD II is the same across all platforms if that's what you're asking.
If you're asking if the ECU is different, the answer is yes. I do believe someone flashed an 11 accord with 09 TSX calibration but lost a lot of internal functions.
Good luck
let's help this guy get his accord boosting it's been on his car for several years but he cannot boost or it goes into limp mode
What is DLC pin?
I gave that to you a while ago on my 8th accord, I can post it here on monday if I'm not to busy at work, the big difference is the communication line and what pin on the ECU it goes to I think the DLC connector is the same
Good luck
Good luck
its been down, like forever... hahahaha
here is what my pin out, its says that my red on 12 is my wen pin, but i've check and double checked on my wiring, and nothing is out of place, so I'm thinking the 09 tsx ones has 1 or 2 pins that could be in a different location than the accord one
Here is an automatic 2009 can anyone take pictures of a manual 2009-2010 DLC connector
indodarknight (04-27-2014)
Where is it located? I might be able to as soon as I get my car back....
cycdaniel
12-17-2019 10:58 AM
Puma Jim
20
10-20-2016 11:59 AM
mugen_kid
11-13-2015 10:38 PM
09-17-2015 09:01 PM
ivegotthenav
09-11-2015 07:51 PM
