Acura TSB: Free ECU Reflash?
Vancouver B.C.
I was just checking out t s x c l u b cause I was bored and I came across a thread reviewing the takeda intake for our cars. I found this information more intriguing. Heres the link
http://.com/forums/2nd-gen-engine/40...alled-one.html (fill in the blank with t s x c l u b to go to the link)
Post #4 reads
"To OP, have you had your ECU reflashed by acura yet? I am able to pull 32 mpg average after getting the reflash from the dealership."
Post #5 reads
"reflash!? I did not know the offered one."
Post #6 reads
"To correct the ignition timing issue. They replace a knock sensor, remove the intake manifold and replace all the seals, and correct the timing. The car pulls considerably more smoothly through the rpm band. It is all under a TSB, and for me and for everyone with an 09 should be free.
And post #18
"The web site will not let me post my information... perhaps I can email it to you?
09-041
Applies To: 2009 TSX – ALL
2010 TSX L4 – From VIN JH4CU2...AC000001 thru JH4CU2...AC00 3
Engine Pings During Moderate to Heavy Acceleration
SYMPTOM
The engine pings during moderate to heavy
acceleration.
PROBABLE CAUSE
The PCM software, combined with knock sensor
sensitivity, may not adjust the ignition timing as
expected.
NOTE: This condition does not cause internal engine
damage. Some engine ping is a desired characteristic
for optimal performance and fuel economy.
CORRECTIVE ACTION
Replace the knock sensor, then update the PGM-FI
software with the HDS. If you’re working on a vehicle
with A/T, also update the A/T software.
NOTE: On vehicles with A/T, you must update the A/T
software to complete the repair.
PARTS INFORMATION
Knock Sensor: P/N 30530-RL5-A01
Intake Manifold Gasket (four required):
P/N 17115-R40-A01
REQUIRED MATERIALS
Acura Long Life Antifreeze/Coolant Type 2
(One gallon repairs about 20 vehicles):
P/N 0L999-9001
SOFTWARE INFORMATION
HDS Software Version:
2.019.009 (August 2009) (gray) or later.
Control Module (CM) Update:
Application Version V6.18.06 or later.
Database Update 05-AUG-2009 or later.NOTE: To avoid an incorrect repair that would not be
covered under warranty, use the software version
listed above or a later version.
The updated PGM-FI software program IDs and P/Ns
are shown below. If these or a later program IDs are
the current ones displayed during the update, the
software for this service bulletin is already installed.
WARRANTY CLAIM INFORMATION
In warranty: The normal warranty applies.
Defect Code: 03214
Symptom Code: 03203
Failed Part: P/N 37820-RL5-A51
Skill Level: Repair Technician
Post #4 reads
Post #5 reads
Post #6 reads
And post #18
09-041
SYMPTOM
acceleration.
PROBABLE CAUSE
expected.
CORRECTIVE ACTION
PARTS INFORMATION
P/N 17115-R40-A01
REQUIRED MATERIALS
P/N 0L999-9001
Defect Code: 03214
Symptom Code: 03203
Vancouver B.C.
Just want to get some feedback on if anyone has done to our cars yet, or even if this info is true. I know the engine pinging was a big issue with our cars so hopefully this news is positive.
Hm, and I wonder if I can have the dealership do this for me even though my car doesn't experience the pinging. Im down for a smoother acceration pull especially if its free.
SeeYou2Crew #2
I did it on mine and it resolved the pinging
what does engine pinging feel like?
there are times when im running 60-70mph and it all of sudden my speed de-accelerate and then immediately accelerates within 1 second.
I got my ECU reflashed but they did not replace the knock sensor. According to Honda, Acura Victoria closed, the first step is to do the reflash. If that doesn't fix the problem then they replace the knock sensor. Needless to say my car will be going back in to have the knock sensor replaced.
As for 32mpg...I'm using on average 10L/100kms.
I wonder if I should put the factory intake back on.
i got this knock sensor and ping shit fixed.. and acceleration was anything but smooth for a good month.. its starting to smooth back out now.. but it still has its jittery days.. it was actually more of a inconvenience then it was a convenience.. I'd rather had the pinging then the moderate acceleration issues I have now.
Dealership says thats how most hondas drive and oh well they can't fix it
wow 10/100km... do u do lots of in traffic driving? i must have got lucky with no pinging issues here.. my car seems fine with smooth acceleration.. mind u my car is at 75xx km, but i a mix of back to back to back traffic, and highway speed driving, and im getting ~8.2/100km, im in calgary btw
Sorry in advance if the dead grandmother comment offended anyone. It is my grandmother I am refering to after all. LOL.
Vancouver B.C.
im not goin to lie...my fuel consumption is always in the 10.6-11.6/100km range lol. But then again I have 19" wheels on and enjoy spirited driving atleast once a tank.
correct in that it is a knock sensor replacement and ECU reflash to fix the pinging. My pining was more of a noise complaint on my part. Other than that, I'm happy.
hmm pinging? what is the sound of that noise? I noticed that my acura makes like a pretty loud idle sound via exhaust pipes.. its kind of like a low, rattle, sounds kinda ricey... is that the pinging? I have no idea how pinging sounds like.. can someone direct me in the correct direction please?
cycdaniel
12-17-2019 10:58 AM
BobbyGraham388
10-22-2015 05:05 PM
