2011 tsx HID problem
So I found the fuse for the driver side headlight / HID under the dash but where is the passenger fuse at? The problem I am having is that sometimes my passenger light works and sometimes it does not. At first I thought it was the bulb but then I changed it out along with the ballast but it is doing the same thing. Then I bought a OEM ballast and replaced it but still having the same problems. When I hold the ballast in my hand I can hear buzzing sound like its is trying to ignite up but it does not. Makes me think that there is a short in the harness wire somewhere. I just want to find the passenger side fuse to make up
a 2011 with HID issues?
very odd.
to troubleshoot; you need to swap bulbs and ballast to the other side to test. if problem follows then you know your culprit.
and I didnt know that the HIDs operate with 2 different fuses.
*hint* you wont find the passenger side fuse.../Hint
very odd.
The following 3 users liked this post by mrstak:
very odd.
very odd.
^why is it blowing in the first place?
its very odd that a 2011 is having problems with HIDs.
my 2006 TL is still on its stock bulbs and ballast.
maybe try bringing it back to John Eagle Acura or Sterling Mccall.
its very odd that you're having lighting problems/fuse problems.
![Exclamation](https://acurazine.com/forums/images/icons/icon4.gif)
like i said it pretty strange that i could blow a fuse and the left lamp would not work but the right side would still. I could have sworn that i saw on the fuse box it said L lo/beam and next to it said L H/beam...
![Yuck](https://acurazine.com/forums/images/smilies/yuck.gif)
2010 TSX
well did some wire testing with a ohm meter and also on the new ballast! was almost going to give up and then I thought to myself, i need to think simple... sure enough after my wife had me change a bulb in her bathroom, i looked super close up at the bulb and boom. The little white rod that has a wire going through it and touches the glass at the very bottom was cracked and power was arcing over to the metal tabs holding the glass.
cycdaniel
12-17-2019 10:58 AM
Legend2TL
Motorsports News
01-31-2016 09:27 AM
