2010 TSX ticking noise from engine?
#41
so I have the same problem now on my 09 tsx and i took to the dealer they told me it was valve adjustment and drive belt tensionor, but i hear a little different noise. sometimes when i accelerate i hear like a rattling grind in the engine or under neath the engine, which sounds like if it was coming from my cat or exhaust but its weird i will try to record it.
I do want to mention that it can be oil because most dealers say they use synthetic but they use like 1 bottle of synthetic and use regular oil which isnt good. it helps them save money haha. i bought the car at the dealer and i always change the oil my self to know what i am putting and what i prefer because some dealers and shops put weak inexpensive stuff.
but on that side note what happened to me and why i do my own oil change was because when i bought the car 2 days after i made a sharp sharp u turn and accelerate and my info light came on stating low oil level which was weird. so i did oil change.
well besides all that. the nose you guys are all hear is pissing me off too. but will have to adjust valves and tensioner's. but if anyone can help me with the other rattling noise while accelerating it will be greatly appreciated.
#42
TSX AMG Type //M i-VVT
#43
Just had this happen to me at 80000km on the odometer, took it into the dealership and they it was valve adjustment. done under warranty. 2009 tsx. also with the vtc actuator was fixed as well also under warranty. talk to your dealership!
#44
^^ mine claims valve adjustment is non needed..
My car has started making ANOTHER weird noise. Also VTC actuator was just replaced last week...
#45
the sound of a valve hittin a piston isnt good. especially if you bend a valve which you will.
#46
My service adviser is an asshole.
#47
go to another dealership =P or a honda dealership. Accords have the same issue apparently (friend is a honda mechanic) and if you are worried about warranty as long as the work is done by a certified shop/mechanic they can't say anything to deny you of your warranty. obviously honda or other shops won't be able to do the work under warranty though
ps. i like your grill
#48
They have to adjust the valves when replacing the VTC actuator it is part of the job if they did't do it ohhhh sooo bad
#49
Car has been running fine though since they did that, last night i thought i heard a strange noise when leaving the driveway but it hasn't reoccurred.
It's on their reccord that i've been to the dealership several times for weird engine noises so if anything does happen past the warranty (i just passed warranty) they will still cover it.
#50
I think it's normal to hear stuff after getting it fixed you get hypertuned into listening for noises
iCrap (11-23-2013)
#51
Yeah that's probably it and i'm probably just paranoid... It's probably fine lol.
#52
hissing noise coming from engine when cold or warm
2010 Acura TSX Base 78k
noise coming from throttle bode (hissing or scratching) when car is cold or warm.
also tappets are making loud noise
DiamondJoeQuimby
09-10-2015 11:40 AM
