will this rim fit?
will this rim fit?
size : 19 x 8.5
offset: 40
Bolt Pattern: 5 x 4.5 (5 x 114.3)
http://cgi.ebay.com/ebaymotors/19-In...Q5fAccessories
offset: 40
so i got the rims already i want to put springs not coilovers i want to know if the teins springs 2.1 front 1.8 rear will it be to low for 19 inch rims?
-Arsenic-
^^^^^ I think you are going to really be pushing it with that rim width and offset be careful especially if you lower
I would suggest going ahead and getting coilover b/c you replace the spring and strut, b/c if you drop that low with your stock suspension especially if it the original struts that came with the car you going to replace them soon, which would then cost the same as if you got like a set of f&f coilovers. Then with the coils you can drop 2.1/1.8 and if you don't think its low enough you can always go lower. But all in all the stech with the 19 still going to look good.
