Wheel Fitment Question (With Pictures!!)
Hi all, recently bought a 2002 TL, and before any of you say it, yes I am planning on getting it running as best it can before doing any cosmetic mods.
Now onto the subject, I've been trying for a few days to try and figure out what wheels I should get later on down the line, and I settled on these Konig Control wheels. Cheap, look good, and seems like they'll fit.
The question for the masses, Will They Fit???
*Based on stock 16" wheels
As you can see, "height" wise they're identical, it's just the new wheels are obviously wider, but what I want to know is if that extra width will cause me trouble.
Thank you for your time!
18x8, +45 ET Aspecs (scroll down)
Also OP, you can go lower
"you're fine, unless you don't have rolled fenders in which I don't know if you're fine."
not sure if you saw this thread...
https://acurazine.com/forums/2g-tl-t...ey-fit-580759/
Hi, OP! Your wheel specs are fine. I'm running 18x8, +45 ET Aspec wheels from the 3G TL and they fit fine. However, my fenders are rolled so I don't know if the results will be the same for you.
Good to know! I honestly just want the wheels to sit flush with the car body, or as close to it as possible (would these be enough?). I did plan on rolling my fenders just to avoid any complications. Also, how low can I go? This is my daily so I'd like to be low of course but not so much than I'm scraping on small bumps!
As for drop height, I believe I did 2" in the front and 1.75 in the back. I definitely lowered it more after that, but you can use that as a baseline reference and if you don't like the results, you can play it by ear and lower it more from there. I had to raise it after
acuradriver925
12-21-2013 03:48 PM
ctmoneyromeo5
2G TSX Photograph Gallery
28
05-25-2011 01:31 AM
