Not your regular offset Q
Old Jun 9, 2009 | 06:39 PM
L3wD's Avatar
FPR pimpin'
ok guys, I'm going for a pretty crazy wheel fitment
20x10... i think im going with 265/35R20... maybe 30 series, but I think i will go with the extra rubber for safety, its ok a bigger profile = lower perch on konis
anyways the main problem is that i need them to stick out of the fender by an inch.. im thinking approx +20, looks like about 25mm in an inch subtract that from 45? but the x10 part may cause complications
Dont worry, I have some mild flares lol
any help would be very much appreciated
Old Jun 10, 2009 | 01:55 AM
z3Ro's Avatar
Mr. 2tone
i hope u have air ride...n gut ur engine bay n completely take out ur rear fender lining just to make ur ride drop more...
if not its just gona look like a scraper...
n x10 on all 4s?
ull have to b all the way up on ur suspension(like a scraper) just to turn if ur rims can clear the suspension...
n kit it for sure!!!
Old Jun 10, 2009 | 02:32 AM
mrchan625's Avatar
uhh I have agressive wheels and I think this is a bit to much x10 with a +20's offset will definately be to much and with a 265 series tire you're going to rub like hell. Well lets see how much your fenders are flared.
and also liek the question above do you plan on doing this on all 4 wheels. If you're going to be that low I dont think you;ll be able to turn your wheel.
Old Jun 10, 2009 | 07:26 AM
MurdaZ's Avatar
u crazy lewd, ha!
Old Jun 10, 2009 | 05:05 PM
L3wD's Avatar
FPR pimpin'
H&R Race springs, with Koni Yellows, i dont want it to be slammed, just so the fender is at the tires or rims
not sure what a scraper is..
n x10 on all 4s?
yea, I need some wide tires to put power down, and it would look weird with the rears smaller than the fronts i think, plus traction in the back will keep it put
the lower offset will push the rims away from the suspension no? the rims should be very close to stock diameter, for 20x7.5 the size is 225/30R20
so the rim width is enlarged 2.5" but the the tires are only 40mm wider, so on x10 265/30R20 should be smaller than stock, and 35 might be slightly larger
well the flares are about an inch wide, i'll be cutting out the stock fender pretty much so its all free space in there
well i do have an extra inch or so to play with over stock. How wide of a wheel do you think can fit up front on a stock TL? I need wide tires for sure. the 265 is toned down, I would love to fit 3xx up there, but i think that may definitely be impossible lol
u crazy lewd, ha!
you know it! go big or go home lol
Thanks for the replies!
Old Jun 10, 2009 | 07:06 PM
DC3328's Avatar
Your Garage
you want to put power down but your getting 20s?
Old Jun 10, 2009 | 07:24 PM
z3Ro's Avatar
Mr. 2tone
lol...thats what i was thinking...if u want to put power down...go wider...not bigger...stay at 18s...but wider...like 9.5 or 10 if u want...n get lighter rims like the enkei rpf1...those r light
on 20s ur rims will b traveling a longer distance...any1 with smaller rims will launch b4 u...then ull b playing catch up...n thats not what u want..
Old Jun 10, 2009 | 07:59 PM
L3wD's Avatar
FPR pimpin'
Lol come on guys, im not talking about putting down 300hp, im aiming for alot more
the 20s are not track wheels, just around town wheels... but even daily wheels need to look good, and be able to put down the power when i want
track rims are gonna be 18's or 17's and the 20's will have the same or very similar overall diameter as stock. only sacrifice will be rotational mass, and i wont get the stickiest tires.. so they wont be so noisy lol
but hey the car is a boat stock, has a 2000w stereo system... trust me 20s aint no thang lol especially with the power i plan to run.
Old Jun 10, 2009 | 08:03 PM
L3wD's Avatar
FPR pimpin'
oh and mr.chan i was thinking you have 9.5 in rear already. so to fit 10s shouldn't be too hard
but the front you have 8.5, do you think a 9 could fit? and do you think with my reasoning of being able to go out another inch i should be able to fit 10s?
remember look at it as if i have a fender thats an inch wider, not just addon flares
Old Jun 10, 2009 | 11:10 PM
mrchan625's Avatar
well yah I'm sure you can fit 10's but you said you wanted a low 20's offset so that makes everything different, right now i have low 40's offset on my 9.5 and theres like a 4mm poke with 0 camber in the rear. You should be able to fit 9's in the front easily if they're flared. But I dont know on the tires man, those are really wide tires and even with aflare I'm almost certain you'll rub or something.
Old Jun 11, 2009 | 02:51 PM
III's Avatar
III
prototype
scrapin' on my scraper .... tl ?
truuunnkkkk boiiiiiizzzzz!
look for old pics of fixedTL's car he had flares/wides
neuronbob
23
Jul 16, 2019 10:48 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
SinCityTLX
55
Oct 11, 2015 01:20 AM
Joe Avesyan
Sep 29, 2015 03:57 PM
Ratheruneeq
Sep 28, 2015 07:41 AM
