-- FAQ: wheel rim size "will they fit?" --
Old Mar 1, 2010 | 04:13 AM
  #881
Sylhety's Avatar
Type S Police Interceptor
If anyone here could tell me if these will rub... I really want them!
Rim Information:
Rim Brand: DZ
Number of Bolts: 5
Rim Material: Alloy
Rim Width: 7.5
Bolt Pattern: 5x114.3
Rim Diameter: 17
Offset: 40
Old Mar 4, 2010 | 12:01 PM
  #882
wside09's Avatar
고고씽
18x7.5 +50, 18x8.0 +50
are these ok ?
Old Mar 11, 2010 | 06:32 PM
  #883
tc5280's Avatar
Flagship Aspec
What about the 18's off an RDX? Anyone know what the width and offset is. I think it would be a good look (somewhat similar) to stock.
Old Mar 13, 2010 | 04:27 PM
  #884
baby z's Avatar
vjtk
I am running basically the same setup, cut your tabs on the rear bumper and you should be good to go.
Old Apr 23, 2010 | 01:17 AM
  #885
03tlCHARCOL's Avatar
WIP-Work in Progress
I'm lowered on Tein SS
19x8 +38
225/35/19
19x9 +38
245/35/19 Will I have any issues running with this tire size on the rear?
Old Apr 26, 2010 | 01:57 PM
  #886
ZEUS'O3TL's Avatar
Low & Slow w/Dubz On My
19x8 +38
225/35/19
19x9 +38
the rears might be a problem with that wide of wheel and tire...i'd say go with 225/35 in the rear as well and FOR SURE a fender roll and trim tabs...
Old Apr 27, 2010 | 12:12 PM
  #887
minisven's Avatar
Would I have any problems running these rims on my '04 automatic TL w/ Aspec body kit? I'm at the stock hieght now but would like to drop it 1"-1.5".
fronts - 19x8 w/46mm offset & 235/35/19 tires
rear - 19x8.5 w/40mm offset & 245/35/19 tires
Could I run a 265/30/19 on the back without any issues?
Old Apr 27, 2010 | 04:09 PM
  #888
minisven's Avatar
Ooops! I posted in the wrong forum. Well, any help would still be appreciated. THX
Old Apr 29, 2010 | 10:57 AM
  #889
DONZ3.2TL's Avatar
are these ok ?
They should fit fine, my current set up is 19 x 8 +51 all the way around and there is still some room, I do however have my fenders rolled and my tabs cut. So you'll probably have to do one or the other or possibly both... I'm thinking you could probably just get away with cutting your tabs since your offsets are good.
Old May 2, 2010 | 11:53 PM
  #890
alexh1266's Avatar
Looking at TSW Montage rims for now with the black gloss. will the 19" x 8" +40 offset fit without rubbing and what size tires? any help is apprecitaed. thanks in advance guys
Old May 5, 2010 | 11:13 PM
  #891
derrick's Avatar
Depends on what you want ... if you want to do some "work" (ie cut tabs, roll fenders) then it will work but you'll have to be careful. Skinny tires might not be enough -- you might have to run some negative camber to make it all fit.
I'm no expert on tire sizes for people pushing the limits on wide rims for a TL. You'll have to do a little reading in this thread. Shouldn't take you no more than 15 minutes to get an idea.
Old May 13, 2010 | 12:24 AM
  #892
notbrant's Avatar
I have an O3 Type S with the OEM kit
I want to fit TL A Specs off an 04, I am told they are 18x8.5, +45 offset.
No drop yet, but I want to get Eibach Pro Kits, 2.1 front, 1.6 rear, I think I will have to cut tabs, do I need a roll? If so, only slightly right? I never have anything in my trunk and rarely more than 1 passenger.
Old May 14, 2010 | 10:07 PM
  #893
-Double Dee-'s Avatar
allrighty im lookin at some 18x7.5 with 45 offset. wrapped with either some 225/45/18 or 225/40/18. which tire size should i get its not dropped and if/when i do it wont be dropped much. from what ive read they will fit fine just not sure on the tires.
thanks
Old May 28, 2010 | 12:25 AM
  #894
klectic's Avatar
double dee - you should be find with that set up, personally i would go for the 40 series as 45 would be too thick. most people run 225/40/18
my question is- will a 215 on a 19 x 8.5 be alright? again, from what i see on most people's set up, they are running either a 225 or 235 on their 19s.
thanks
Old Jun 4, 2010 | 09:43 PM
  #895
vigilante1's Avatar
1) rim size- 19"
2) rim width- 9"
3) offset-+26
4) bolt pattern- 5x114.3
5) Brand- Racing Hart Evolution
Old Jun 7, 2010 | 10:31 PM
  #896
derrick's Avatar
I'm gonna say ... no way unless you are going to:
a) roll fenders
b) cut tabs
c) run stretched tires
d) crazy camber
I'm sure it will 'fit' but it will most likely not look very appealing unless you are lowered and have a good suspension to accommodate the skinny tires you will have to run to make it work.
My
Originally Posted by vigilante1
1) rim size- 19"
2) rim width- 9"
3) offset-+26
Old Jun 10, 2010 | 05:01 PM
  #897
MrChanh's Avatar
anyone know if asa st4 wheels will fit? all i know about them are they are 18x8 with low pro tires. i picked em up from a co worker and he said he doesn't remember the offset. maybe 35? would it fit?
Old Jun 11, 2010 | 02:58 PM
  #898
themiccivic's Avatar
What to put
will the ron jon legend 19x8 +32 (3g offset) with 235/35/19 car is stock height now but would like to slam it with f&f coilovers and camber kit
Old Jun 11, 2010 | 05:05 PM
  #899
02type-s's Avatar
-Arsenic-
You will need a 225/35/19 tire, no way a 235 will clear with that offset, a little camber, rolled rear fenders, and cut rear tabs.
Old Jun 11, 2010 | 05:06 PM
  #900
02type-s's Avatar
-Arsenic-
are these ok ?
Yeah, super weak specs tho....they will look a little sunk unless you run spacers
Old Jun 11, 2010 | 05:26 PM
  #901
What to put
Is that stock or dropped i know i would need it dropped but stock is it going to stick out at all or at most be flush with the fenders. Car has a camber kit already so i can add neg camber if that is needed but i would like to keep it at 0 camber till it is dropped unless it sticks out.
Old Jun 13, 2010 | 10:21 PM
  #902
axright's Avatar
7th Gear
Right now im running 18x8 38 offset..... they are perfect
Old Jun 14, 2010 | 11:02 PM
  #903
MrChanh's Avatar
got any pix? i slapped them on the other day and it looks like a mexican low rider lol. i am sitting on oem 4x4 springs right now though.
Old Jun 15, 2010 | 12:25 AM
  #904
dwmauney's Avatar
Axis Hiro staggered
19x9.5 rear
19x8.5 front
Old Jun 18, 2010 | 08:28 PM
  #905
junny's Avatar
6th Gear
17x8 45offs que goma debo usar en 2gentl?
Old Jun 19, 2010 | 08:13 PM
  #906
BARRACUDAMOTORS's Avatar
HI, Im new on the site Interested in buying wider tires on stock wheels, what would you think if they will rub 235 on stock tl-s 17s
(2002 tls) Thanks
Old Jun 19, 2010 | 08:28 PM
  #907
(2002 tls) and what is offset on stock wheels and could I go with 42 on 17s and 235 thanks
Old Jun 19, 2010 | 11:40 PM
  #908
TRafalik's Avatar
Blitz 01
17x9+42
OR
Blitz 01
17x7.5+35
going to be dropped on f&f type 1's
What ones would fit better? If so whats the ideal situation tirewise and if any modifications would be needed.
Thank You!
Old Jun 25, 2010 | 01:54 AM
  #909
tl_ster's Avatar
will 17x7 wit 40 offset fit?? on 2nd gen TL
Old Jul 12, 2010 | 12:07 AM
  #910
taintedplay's Avatar
these are two i found on craigslist:
rims and tires,
18" Maxxim Deadlines in 5x114.3 w/ Khumo tires
specs: 18x7.5 45mm offset ( found on another site)
http://dallas.craigslist.org/ftw/pts/1820178778.html would these be considered low profile? he doesent mention tire size
or:
not named mesh wheels that need tires. what size tires would fit well?
http://dallas.craigslist.org/ndf/pts/1785363175.html
specs: 18x8
et35
Old Jul 19, 2010 | 12:02 PM
  #911
derrick's Avatar
Looks like an RSX in the pics ... I would double-check the tire size since the OEM 16" that come with an RSX is 205/55-16. A similar circumference for 18" would be around 215/40/18 ... hopefully 225/40/18 is on the car so it would fit better.
specs: 18x8
et35
Would have to do some playing around / modification (trim fenders / cut tabs) for you to have a shot at trying to get these rims to fit. Also ... no mention of tire size. If it fits a Mustang and Japanese cars, you'll probably need some hubcentric rings for it to fit properly (ie bolt pattern isn't exactly the same).
Good luck on your search.
Old Jul 21, 2010 | 10:04 PM
  #912
silvertl510's Avatar
what do you guys think about fitting
19x8.5 +42 or +43
tires: 235/35/19
-the guy im buying them from isn't sure which one it is from those two tho, but all four wheels are same offset.
-i am dropped for f2 coils and thinking about going lower after i get wheels, only if it is possible.
but would this set up fit wit only rolling fenders? or would i have to cut/pull them also?
these are some pic of my drop:
i dont want to run a big negative camber, dont really wanna be changing my tires alot.
Old Jul 29, 2010 | 12:54 PM
  #913
cplmct's Avatar
I'm hoping someone can help me out.
I'm currently riding on TIEN SS
I'm looking at a set of rim
SPECS: 18 x 8 offset +42mm and hubs of 73.1mm
Can I make this work? And if yes, what size of tire will make this works. Some people are telling me that the front will fit but there will be some rubbing in the rear.
Old Aug 1, 2010 | 07:25 PM
  #914
derrick's Avatar
The thinner the better ... 225/40/18
You have to trim tabs and roll fenders to ensure you don't rub. A little negative camber might be needed if you slam yourself to the lowest setting.
Good luck with your set-up.
Old Aug 3, 2010 | 10:32 AM
  #915
Joey tl's Avatar
04' tl 6 spd
does lexus spyder rims fit on a 3G tl with brembo brakes
Old Aug 5, 2010 | 09:45 AM
  #916
V_Langs_3.2TL's Avatar
Rice Patrol
Hey I have some questions
So I just got some lowering springs (Eibach: 2.1/front 1.6/rear)
and I'm going to install them this weekend. I have stock rims right now but and looking to buy these:
Will they sit flush? I know the offset and width look right, but they won't rub if the car is low will they? I don't have front tabs under the fenders (ran over some serving trays a few years ago) but I do in the back. Not opposed to cutting them out, I just want to make sure it fits without any issues and I don't have to camber them
Old Aug 5, 2010 | 09:51 AM
  #917
SLushhYYY's Avatar
Keep It Simple in
^Sit flush with what? the fender? lol no...
The only thing flush will be how to 225 sits on the 8"
You'll get away without having to roll your fenders/cutting tabs..if you looked back at page 1, you would have known this already
Old Aug 5, 2010 | 09:55 AM
  #918
Rice Patrol
I read it haha I was just confused. I didn't want to post until I read everything and then ask the question.
but thanks for the help :-)
I'm good at engine mods and the like (used to be a civic head) but when it comes to rims and wheels I'm a noob and not ashamed to admit that :-D
Old Aug 7, 2010 | 01:45 PM
  #919
Ep3moschini's Avatar
Like a BOSS
can I run 19x8.5+30 Fronts and 19x9+37 Rears?
Old Aug 17, 2010 | 02:13 PM
  #920
notbrant's Avatar
I am trying to buy some tires in the Black market.
I have an 03 dropped about 2.25 in front, 1.7 in back.
After alignment, rear camber is about -1.3 degrees
The rims I want are 18x8, running 245/40/18 tires, I would ultimately get 225 tires when these ones wear out, but I was wondering if I could get these to fit with only a roll, or will I need a slight pull as well?
