Accord lowering springs on TL?
Anyone know if 2002 Honda Accord lowering springs will fit a 2gen Type-S? I was told it will fit but ruin suspension and give uneven rub on tires? And if they fit what should I look at to make sure they are kosher and not garbage?
They're pretty much the same car so it should work. Look the springs up on the manufacturer website for both cars and see if they're the same part number. As for ruining the suspension, it really depends on the drop. A slight drop won't really affect much but an aggressive drop will cause camber wear on your tires.
yea as long as there are for the v6 you will have no problem ,I am going to use the Megan Racing lowering springs and call the Megan rep and i told him i have a 00 tl and he checked with the tech reps and they said np problems ok
You haven't even mentioned the brand and you're worried about the color? Give me a break man, as fsttyms1 said it doesn't matter what color they are. Nothing wrong with a little contrast depending on the color of your car. Make sure you're picking up some quality springs, color doesn't matter, quality does.
jmoney2001
08-12-2019 06:23 PM
1fatcrxnem1
22
06-01-2018 01:23 AM
