18x8 Et40
4th Gear
18x8 Et40
So I Have Had My Car For A Month Now And I Have Searched Like Crazy And Goton Alot Of Info But As Much As People Frown On It There Is A Wheel That I Want That Only Comes 18x8 With A 40 Offset. Is There Anyone On Here That Is Running This Size Wheels On A Second Gen?
The ICEMAN
I ran an 18x8 with a 40 offset for two weeks, in the front only, never tried the back. It rubbed only over large bumps while I was driving too fast. Yes, I was lowered. If you want to run that in the back be prepared to do some major tab cutting/fender rolling.
I have 18-8 (235 40s) with 45 offset and still had to do a bit of work to get clearance on bumps.
I am lowered 1.5 inches on Teins, and even stiffened up- its easy to grab some fender lip with the outer tire edge.
Thats part of having 235 instead of 225 which do actually clear- just a little too wide for a TL.
Nothing some rolling -cutting and bending wont cure
Originally Posted by ADUBWHITE
My Main Reason For Asking Is To See If It Would Stick Out Too Far And Look Like A Mexi Ride. Im Prob Not Goin To Lower It For A While
4th Gear
Well I Guess I Already Look Like A Tractor Then......the Wheels On Here Now Are 18's And They Are In The Worst Shape I Have Ever Seen Wheels So I Have To Replace Them And Im Still Browsing Forums And Learning About These Cars. Im A Mini Trucker With His First Import! I Know Nothin About These Cars
Something is missing...my
Originally Posted by fsttyms1
You will look like a tractor not lowered.
I have 235/45 17s +45 and the day i loaded my trunk I rubbed. Cut the tabs and am pretty sure that I am not rubbing any more.
Add another 5mm to the equation and who knows. You will certainly rub on a big bump or opposed bump; how much is the question.
very good idea
The fourth wow power leveling latest game in wow power leveling Warcraft series is ‘wow power leveling’. Also known as wow power leveling, it represents a wow power leveling multiplayer online
mrkingstonvi
02-22-2016 01:53 PM
Inspire08
10-30-2015 04:00 PM
