Wow, that never happened before...
Old Apr 18, 2006 | 07:36 AM
NSXNEXT's Avatar
Coming home from work
Coming up to a 4-way intersection
Light turns green
I start to turn right onto next street
Having a hard time turning the wheel
Look down and the car has shut off.
Was able to limp into a parking lot. No check engine light (hooked up my ODBII scanner and got nothing too)
Took out key, tried to start it back up. Started right up. Been fine since.
No clue what that was. Any ideas?
One coincidence I thought about was that I got another reminder about the ignition switch recall on my 99. Maybe it's going bad?
Old Apr 18, 2006 | 07:47 AM
SatinSilverTypS's Avatar
ChairmanMaoSaysRTFM
at least you didn't get hit. sorry to hear about it.
SSTS
Old Apr 18, 2006 | 08:14 AM
PenancE's Avatar
could be ur ignition like u said...weird lol
Old Apr 18, 2006 | 08:23 AM
NSXNEXT's Avatar
Was reading about the recall. It says that the electrical contacts in the igintion switch can wear prematurely causing the engine to stall without warning.
What a weird coincidence that I got the card in the mail the same day I had the problem. Who da thunk it?
Old Apr 18, 2006 | 10:05 AM
honda_inspire99's Avatar
Skeet Skeet Skeet
Yup thats the problem, the ignition switch/lock there is a recall on it I had mine done a couple months ago. Its annoying and dangerous at the same time so you should make and appiontment ASAP and get it fixed
Old Apr 18, 2006 | 12:07 PM
georgy_d28's Avatar
Yeah the two days before the replacement of my ignition switch the car died a good 30-40 times. i got stuck for 45 minutes at a light trying to restart and keep my car running. luckily it was 3 am. it only took about hour when they replaced mine and i got to drive an MDX which was pretty nice
Old Apr 18, 2006 | 01:08 PM
OttawaGuy's Avatar
same thing happened to me but i was going down a hill and my car shut off almost rolled right threw a four way intersection... i think i stepped on my key chain and pulled the key out of the ignition a bit lol
Old Apr 18, 2006 | 02:35 PM
fsttyms1's Avatar
SOunds like possibly the ignition switch
Old May 5, 2006 | 09:53 AM
NSXNEXT's Avatar
Happened again this morning. This time I was on 95S in Joisey and the car died while I was doing 80 in the middle lane. Was able to get over to the shoulder.
Going in for service on Tuesday.
Old May 5, 2006 | 10:04 AM
fsttyms1's Avatar
bummer. hopefully it turns out to be something they can find and not a "Cannot Duplicate"
Old May 5, 2006 | 10:08 AM
Comet2404's Avatar
Flyin' and Drivin'
Yeah my old 99 conked out on me on the freeway once. the key was finicky, and if I hit a bump, or accidently brushed up against the key, it would cut off. Also, instead of turning the key to start it, and releasing it, I would have to release the key very slowly from the start position otherwise when it sprang back into position 2 it would stop the engine. After I got the ignition switch replaced at no cost, it was totally fine.
Old May 5, 2006 | 10:40 AM
NSXNEXT's Avatar
No it's definitely the ignition switch. It'll be fixed next week.
Old May 5, 2006 | 12:08 PM
fsttyms1's Avatar
Old May 5, 2006 | 02:05 PM
PenancE's Avatar
woot
Old May 5, 2006 | 02:11 PM
NSXNEXT's Avatar
Originally Posted by PenancE
woot
You mean
Old May 7, 2006 | 09:29 AM
joe80055's Avatar
Interesting.. I called Acura client services, .. apparently, the ignition switch regarding the recall was installed without me being told so... weird.. isn't it?
SidhuSaaB
May 30, 2020 12:40 AM
joflewbyu2
Oct 8, 2015 11:16 AM
Houston
Oct 8, 2015 01:27 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
