Wont Pass 3000RPM
Old Oct 13, 2012 | 10:51 PM
BxTrini_TL's Avatar
Wont Pass 3000RPM
I got a 00' TL that wont pass 3000rpm. When at a dead stop its idling at 500rpm and acting like its gonna cut off but it doesnt. This just happened today CEL and TCS lights are on. It happens when it is cold out but it would always pass 3000rpm. Today was the first time it didnt pass 3000rpm. Can someone please help. Thanks -Rich.
Old Oct 13, 2012 | 11:20 PM
assclown's Avatar
2000 acura tl FPR
You're going to need to get your codes read because we're not going to be able to tell what's wrong without the DTC.
Old Oct 13, 2012 | 11:22 PM
BxTrini_TL's Avatar
Ok cool. Thank you very much I will get the codes first thing in the AM. Again thanks.
Old Oct 14, 2012 | 01:05 AM
01tl4tl's Avatar
you are in LIMP Mode,the engine thinks something horrible has gone wrong and limits it to 3k so you can limp off the freeway to a safe area and call the tow truck
do not be cruisinhg around with it like this
maybe coil failure, old plugs plus coil prob,,many things
the warning lights mean far more than what they say
codes are the next step- write them down fully,,P0140 as an example
and any words the parts store may offer with each code
multi cyl misfire is usually an easy fix!
how old are the spark plugs? correct 8 dollar each NGK installed if replaced
ever remove intake manifold to clean out the egr passage and ports?
needed every 75kmiles
Old Oct 14, 2012 | 01:11 AM
BxTrini_TL's Avatar
Exclamation
hey thanks ... Tomorrow i will pull those codes. Its parked until i fix it. The car been in my family since the 1st owner nd the last owner (bro-in-law) told me its an o2 Sensor. i never changed any o2 sensor nd all summer the car been running great then all of a sudden today it just started acting up.. Sucks..
Old May 28, 2013 | 06:48 AM
sexysteezy's Avatar
7th Gear
@BxTrini_TL
Did you ever figure out the problem??
Old Sep 12, 2013 | 03:56 AM
BxTrini_TL's Avatar
Yes.. it was the o2 sensor.. had to get cali emissions. Sold the car currently in the process of getting a 04 6 speed
Old Sep 12, 2013 | 08:03 AM
3.2TLc's Avatar
Which O2 sensor was it, front or back one ?
MilanoRedDashR
Oct 2, 2015 10:49 AM
kb1rl
Sep 30, 2015 10:17 AM
2ManyHobbies
Sep 24, 2015 09:23 PM
rangomango
California
Sep 24, 2015 05:47 PM
tmux
Aug 31, 2015 10:27 PM
