At Wits End
Old Nov 24, 2009 | 09:29 PM
AcuraCar99's Avatar
What?
Question At Wits End
Hello All,
Well im about to call it quits on my car...
I posted a few time about doing a tune up on my car and there's where my problem started.
Shortly after the tune up i got VSA and ! lights. I went and had the codes read..
P1399 - Random Misfire
and misfire codes on all cylinders...
I replaced the plugs resolved the issue with 3 cylinders but still misfireing
I replaced all of the coil packs - no change
I pulled the plugs tonight to exchange them with new NGK platinum plug to see if it would resolve this issue and of two of the plugs had trace amounts of oil on them.
I have 2 cylinders that don't even fire noted by the X
Back of Car
XOO
XOO
Front of Car
When i pull the lead on the above mentioned cylinder no change in the rythm on the motor, but if i pul the lead off any other the rythm changes...
I'm so ready to call it quits on this car and trade it in...
Any ideas on the problem and potential fixes?
Old Nov 25, 2009 | 04:32 AM
Rajca's Avatar
wham bam thank you ma'am
what exactly did u change during the tune up?
Old Nov 25, 2009 | 08:24 AM
fsttyms1's Avatar
what did you do for the so called tuneup
Give us a little more info so we can help out more. Did you try swapping the coils from those cyls to see if it still does it on 1 and 4?Have you inspected the wiring for any damages to the coilpacks?
Old Nov 29, 2009 | 08:50 PM
AcuraCar99's Avatar
What?
The only thing I changed in the tune up was the spark plugs and the filter.
Yes i tried switching the coil packs, mind you the coil packs are new.
Old Nov 29, 2009 | 09:08 PM
Rajca's Avatar
what kind of spark plugs? were any of the boxes damaged or the spark plug it self damaged?
Old Dec 1, 2009 | 07:11 PM
AcuraCar99's Avatar
What?
End result!
I took it to my mechanic and they found that I had a bad injector. Replaced it @ $89.00 for the injector and 311 in labor and diagnostics.
The car is purring like it should....
Big relief!! Thanks all for your help and feed back... Especially you fsttyms1...
Old Dec 1, 2009 | 09:15 PM
totaledTL's Avatar
Wow, $311 in labor. Has anybody else had to pay to get this done and was it comparable?
Old Dec 1, 2009 | 09:21 PM
juanclopez2786's Avatar
thats expensive. the shop im at cancels out the diag charge if you decide to fix it with us. i know alot of places aound here do that. its dumb easy to diagnose bad injectors when u have new plugs and coil packs.
Old Dec 4, 2009 | 01:06 AM
thinhthan's Avatar
you should have just hooked up a scan tool to it and it should tell you
jterp7
3G MDX (2014-2020)
Feb 3, 2016 08:34 PM
ceb
ILX
Sep 27, 2015 10:56 AM
Rcelestino93
Sep 23, 2015 10:01 PM
Brandle34
Sep 23, 2015 07:20 PM
