Winter project done, now need help
Ok, winter is done here, i've put my car together and took it for the first drive since October.
A lot of stuff were done, will list them after as well as picz, BUT
But i need your help now, i have list of problems came out.
1) Where is outside temp. sensor located?
My dash just showing "---" instead of temp, so i guess, i've done something with it, maybe just connector.
2) Mirror control buttons are not working, will CL-S or 99 TL one, fit 02 TL-S?
Happened after installing LED there, maybe resistors touches something or maybe i f**ked it up...
3) Headlights leak, will just resealing in oven fix it?
Washed it and condensation was there... i've removed bottom parking light, but plugs are there, so i'm sure it's leak... maybe reseal + silicon?
4) Aftermarket catback rubber mounts?
My exhaust tips are on different high, can i just buy another rubber mounts to replace OE? will it fix it?
That's it what i've noticed for few hours of driving around so far...
Hope to get some help from you guys!
that was exactly i 'm thinking, coz i haven't find anything a can do with wiring between sensor and module.
Is it separate plug for temp? coz everything else is showing on dash, milage, doors...
UPDATE: A/C is not working at all...
Just found that it's not even trying to start, coz RPM's are staying on the same level.
What it can be? does it related to temperature sensor?
will check it tonight.
