Winter project done, now need help
Old Mar 17, 2010 | 01:05 AM
mastini's Avatar
Ok, winter is done here, i've put my car together and took it for the first drive since October.
A lot of stuff were done, will list them after as well as picz, BUT
But i need your help now, i have list of problems came out.
1) Where is outside temp. sensor located?
My dash just showing "---" instead of temp, so i guess, i've done something with it, maybe just connector.
2) Mirror control buttons are not working, will CL-S or 99 TL one, fit 02 TL-S?
Happened after installing LED there, maybe resistors touches something or maybe i f**ked it up...
3) Headlights leak, will just resealing in oven fix it?
Washed it and condensation was there... i've removed bottom parking light, but plugs are there, so i'm sure it's leak... maybe reseal + silicon?
4) Aftermarket catback rubber mounts?
My exhaust tips are on different high, can i just buy another rubber mounts to replace OE? will it fix it?
That's it what i've noticed for few hours of driving around so far...
Hope to get some help from you guys!
Old Mar 17, 2010 | 12:47 PM
mastini's Avatar
anyone?
Looks like it's behind metal bumper, i thought it's airbag sensor will check it tonight.
Old Mar 18, 2010 | 07:06 PM
mastini's Avatar
Wow.... no replies for two days
Old Mar 21, 2010 | 11:27 PM
Srb's Avatar
Srb
00 ssm
For the temp display, is everything for the heater control on the dash plugged in? I know that if it is not fully connected behind the dash, the display on the cluster will show ---
Old Mar 21, 2010 | 11:35 PM
mastini's Avatar
that was exactly i 'm thinking, coz i haven't find anything a can do with wiring between sensor and module.
Is it separate plug for temp? coz everything else is showing on dash, milage, doors...
Old Mar 22, 2010 | 02:25 PM
Srb's Avatar
Srb
00 ssm
Does your heater or a/c work when you try to turn it on? Did you remove your dashboard recently?
Old Mar 22, 2010 | 03:45 PM
mastini's Avatar
^ i did, but everything else is working fine.
Gonna try to remove it again and check wiring.
Old Mar 25, 2010 | 09:43 PM
mastini's Avatar
maybe A/C works kinda weird... anyway - gonna play with it over weekend.
Old Apr 3, 2010 | 03:20 PM
mastini's Avatar
UPDATE: A/C is not working at all...
Just found that it's not even trying to start, coz RPM's are staying on the same level.
What it can be? does it related to temperature sensor?
Old Apr 3, 2010 | 04:27 PM
Srb's Avatar
Srb
00 ssm
Check behind the dash. Sounds like it's not hooked up to the wire harness. Make sure all the plugs are connected back there.
Old Apr 15, 2010 | 08:05 PM
mastini's Avatar
Found it and connected back A/C works! Yayayayay!
Marcelechka
Home & Garden
188
Sep 11, 2022 11:53 AM
tsx_boy
Dec 13, 2019 08:33 PM
kev87a
Oct 18, 2015 02:03 AM
dirleton
20
Oct 16, 2015 01:48 PM
polish_pat
Sep 30, 2015 12:22 PM
