Windows Fogging
Old Dec 3, 2008 | 09:40 PM
jsbtn's Avatar
Windows Fogging
First, Happy Holidays to everyone.
I've had an issue with the windows fogging in my 2000 TL for a few years now. Whenever it gets cold, I struggle to keep the windows clear.
When I first start the car, with the climate control set on auto, the bottom of the windshield initially fogs for several seconds then clears. Once the engine gets warm enough and the heat starts, all of the windows will begin to fog. I switch to the defroster, but it could take 10 minutes before it finally clears the windshield and eventually the front door windows. This condition occurs regardless of the weather (wet, sunny, doesn't matter). If it is cold and wet outside, or if there are mutiple people in the car adding moisture, I have to keep the defroster on full time. I now also keep the A/C on which helps a little, but the condition persists. All windows will fog up.
I've cleaned the windows, etc. to no avail. There is no tell-tell smell of water being trapped in the evaporator or a leak in the system.
Has anyone experienced this and found a solution?
Thanks,
Steve
Old Dec 4, 2008 | 01:59 AM
Gfaze's Avatar
S E L L
You should use the "defroster" and not the "auto" option during the winter months. You shouldn't be experiencing much, if any, problems with window fogging if you use the defroster setting exclusively. I have the same year TL and I never have problems with the windows fogging up. The only other thing I can think of is that maybe your cabin filter is plugged up and not allowing proper airflow for your climate control to function properly. Do you also have problems keeping the car cool during the summer? If so, this may be your problem and you'll have to replace the cabin filter. Good luck.
Old Dec 4, 2008 | 10:07 AM
newperson's Avatar
There's no Acura in
Doesn't the A/C have to be on for the defogger to work? The front defogger needs it but not the rear defroster if I remember correctly.
Old Dec 4, 2008 | 10:52 AM
totaledTL's Avatar
When you select 'defrost' the compressor should automatically engage.
Old Dec 4, 2008 | 01:47 PM
harbtheforcaster's Avatar
no the defrost will still work with out the ac on you can disable the ac while the defogger is on. maybe you should try the anti fog stuff like rain x or somthing cause even though it may get better with the ac on it may be 100 times better with a product that you actually apply to the windows.
Old Dec 4, 2008 | 01:48 PM
rob-2's Avatar
Does your A/C work? It sounds like it's not working.
I have the same car, when I hit front defroster the A/C comes up and the window clears up in seconds (on the side). If you have water on the outside use your wipper blades.
Old Dec 4, 2008 | 02:00 PM
Phrosttz0's Avatar
yeah mine clears completely under a minute..
Old Dec 4, 2008 | 04:20 PM
fsttyms1's Avatar
Make sure the Recirculate button is OFF.
Old Dec 4, 2008 | 04:57 PM
MurdaZ's Avatar
what he said, also i notice if i have it on auto it doesnt unfogg, unless u press the button to the right of the recirculate button, the one with the windshield looking like this \_/, that will blow it out the vents closest to the windows and unfogg it asap, then u can put it back on auto if u like
Old Dec 4, 2008 | 05:39 PM
gold2003tl (90)'s Avatar
2003 TL-p
get ur AC checked out - it doesnt sound like its strong enough. get it recharged. then u should be fine. how cold is the coldest AC'ed air in ur car right now? you shoud be able to get 45 degree air out of it. i had to get mine recharged 2 years ago.
Jul 16, 2017 07:33 AM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
Avenger411
Oct 11, 2015 03:53 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
rhdune16
Sep 28, 2015 11:31 AM
