window fog up real quick
i find this annoying since it doesnt happen to any other cars i drive, my windows tend to fog up real quick. I do put the blower on by the windshield with a/c on. After it clears up i either turn the fan off or just put it on low with a/c off. Within couple of minutes it fogs up again?
I agree-- clean windows and apply anti fog !
Ck radiator pressure- if you are leaking coolant at the heater core it will fog the windows constantly
If you bring coffee or have wet hair,,that will fog them too~
Need a fan running to move the air
with winter upon us its important to make sure no leaks are in the heater core-
a mini radiator itself- located in the cabin with the blower motor and filters.
that can happen when coolant sits in there uncirculated for the summer.
I had one go and the windows were coated in glycol from it--not good for seeing thru
its easy to pressure test the system to ck for leaks--
IF the rad or res bottle are low at all- then test for leaks
While you are there- clean the battery terminals and test electrical system
winter calls for more drain on batt at one time, all the time!
seat heat, lights, heater, stereo etc will tax a weak battery ,,to death!
average battery life now for normal battery brands is 3- 4 years--they go fast!
optima and interstate brands seem to last longer.. for more money
Original Owner / Oct 1998
If you don't know what coolant smells like, stick your finger into a COLD radiator, and give it a sniff...
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
its a sickly sweet smell
xsilverhawkx
09-28-2015 06:51 PM
