Wierd Noise
Old Feb 22, 2013 | 06:42 PM
hondakid23's Avatar
Wierd Noise
Had a quick question as I was driving today my car is sounding a little wierd It sounds like it has a custom exhaust on it , when I drive 20-30 mph it idles above 1500 to 2000 Rpms and then seems like it takes a long time to get outta that specific gear. No check engine light and I doubt its the tranny bec no jerking of any such. Maybe can a exhaust leak cause this. Also when I start the car it starts up pretty loud after replacing air filter.
Old Feb 22, 2013 | 07:20 PM
HairyMonkey019's Avatar
If there was any exhaust modification it should be quite obvious.
Our cars are really quiet in stock form.
Old Feb 22, 2013 | 07:36 PM
hondakid23's Avatar
Havent done any mods on the exhaust all stock
Old Feb 23, 2013 | 06:47 AM
3.2TLc's Avatar
Hey Hondakid23, perhaps when the air filter was recently replaced....the top retaining cover for the airbox enclosure is misaligned or a bad seal.
If the exhaust is still original from the factory, it may require a closer inspection for loose joints or cracks causing the exhaust to leak out somewhere. It's best to do this up on a rack.
Old Feb 23, 2013 | 01:24 PM
hondakid23's Avatar
Yes thats what I thought because I had a striped screw and had trouble opening the air filter.
Old Mar 8, 2013 | 04:16 AM
32tl00tuneacura's Avatar
yeah the slight hang up in gear would be charecteristic of a vacuum leak... weird that the mil doesn't come on. And if you were to remove the air box completely (or if u install a cold air) it results in a sound that is similar to an exhaust leak. So yeah prolly a leak somewhere in the intake like 3.2TLc said.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
