Weird noises??HELP PLEASE!!!
Old Apr 1, 2012 | 09:55 PM
acu23's Avatar
Hi I have some really weird issue's with my TL i have some noises i cant explain..First is when coming thru a right hand turn at speeds over 30-40 mph i hear a thumping noise not like metal clanking or rubbing but a slow thumping noise, thru a turn around it thumps about 4-5 times but there is no noise in a straight line or in a left hand turn
Second When getting up to speed or at low speed there is alot
of vibration/rough noise under my feet and the passengers feet i mean you can really feel it
Any input is greatly appreciated, Thanks
Old Apr 2, 2012 | 06:15 AM
fsttyms1's Avatar
check your sway bar endlinks.
Old Apr 4, 2012 | 11:54 PM
acu23's Avatar
That was one of the first things i checked,ive checked all of the ball joints made sure everything was tight,still nothing...
Old Apr 5, 2012 | 01:27 AM
kidduce's Avatar
I'm assuming you have removed the wheels and jacked the car up to see if anything is visibly messed up?
Old Apr 5, 2012 | 10:14 AM
01tl4tl's Avatar
outer cv axle bearing will make noise, test from stopped to very low speed and wheel fully turned,click click click,, which can become so bad it makes other noises at higher speed
inner cv axle bearing will make the shake on accelleration and felt in your feet
replace entire axle assembly with a NEW not rebuilt one--try NAPA auto parts- many reports of good part on first try!
other possible : bad hub bearing
Old Apr 5, 2012 | 10:17 AM
01tl4tl's Avatar
ck the CV boots --pull apart the sections looking for traces of grease, or dirt stuck on grease, is a good clue
If thats happened- grease leaks out and road grit gets in = toast the CV beaings
Old Jun 15, 2012 | 09:54 PM
acu23's Avatar
good stuff guys im going to check all this out tomorrow for sure
Old Jun 15, 2012 | 09:58 PM
DphAmT's Avatar
I would assume its a axle problem as well. My girlfriend's integra is acting up as well. It's easy to replace on an integra though.
Old Jun 18, 2012 | 07:23 PM
acu23's Avatar
also to note there is no clicking noise when turned to full lock in either direction the cv looks good
Old Jul 8, 2012 | 05:18 PM
acu23's Avatar
checked bearings there good also just got back from dallas new tires all the way around still the same noise its loud but it doesnt effect how the car drives there isnt alot of shaking or anything like that
Old Jul 15, 2012 | 09:40 PM
acu23's Avatar
changed bearings no change...i believe the noise is coming fro the intermediate shaft bearing
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
