VSA and Warning light one
Old Aug 5, 2006 | 01:29 AM
victorvu's Avatar
Exclamation VSA and Warning light one
i got the VSA on and it will turn on after i got the car warmed up for about 1-5 mins. VSA button doesnt work. Also the Warning light is on the ! with the triangle around it is always on never turns off. someone help me. you think its because i changed the cluster? because i cant remember if it was on when i changed the cluster or not.
Old Aug 6, 2006 | 11:29 PM
Costco's Avatar
Did you unplug the battery then reconnec it?
Old Aug 8, 2006 | 02:01 AM
adamlee05's Avatar
Thread Police Chief
No clue as to how letting the car warm up would affect the VSA.
But as to removing the cluster....is it possible you might have ACCIDENTALLY left the plug to the VSA switch disconnected behind the panel? I've done that with my TCS and dimmer on accident before, couldn't figure it out at fist
200 posts for you
Old Aug 8, 2006 | 11:49 PM
victorvu's Avatar
yea
i dont know either never removed the cluster a second time ill check it tomorrow. 202 now.
Old Aug 14, 2006 | 03:16 PM
tits legendary's Avatar
Goon!
Not sure about the warming up thing but I do know that when my tranny was going the VSA light came on and wouldn't turn off. Not sure if that could be your problem. The orange light should not be on all of the time though.
Old Aug 15, 2006 | 01:52 AM
victorvu's Avatar
i know the warning light would turn on if you turn the VSA off i think my VSA is malfunctioning. i dont know why it wont work. maybe i have to reprogram the car because i cant push the VSA button on my car. so im guessing something is really wrong with the car. ive been driving with it on for over 6 months now. and i hope i didnt damage anything
Old Aug 24, 2006 | 04:53 PM
CJITTY's Avatar
Ackniculous One
My VSA light came on once while switching lanes on an uneven lane change and would not turn off. So, I parked, turned off the car, restarted, never came on again. Sounds like you may have a faulty switch or your VSA is on it's way out or having errors. Try resetting the ECU or disconnect the battery for a while to reset the codes. See if it does it again..if so, dealer or Acura tech time I'm afraid.
Old Aug 24, 2006 | 05:50 PM
Costco's Avatar
....and make sure you got your radio code before you disconnect the battery unless you got a aftermarket head unit
Old Aug 25, 2006 | 12:22 AM
seattle dale's Avatar
look at my thread below "(Partial Christmas tree)" Look familure. Is your check engine light on too? I'll let you know what the dealer has to say about the situation next week. After doing a little research sounds like either a bad EGR valve (waranteed to 80 grand ) or my second tranny begining to take another dump, but shes still running fine?
Old Aug 28, 2006 | 08:26 PM
Victor any updates on your problem. i have the stealer trying to screw me over this issue. Did you ever figure out what is causing our problem. Thanks in advance
Old Aug 29, 2006 | 12:29 AM
victorvu's Avatar
i dont have any updates. what did the dealer say about your problem? i think it might be my throttle body or i just need to get my car reprogrammed. if i go to the dealer i would probably just ask them to install the oil jet also for free. do you think i should disconnect the cluster, and then remove the battery and then plug everything back? just to see if that resets the cluster?
Old Aug 29, 2006 | 09:36 AM
fsttyms1's Avatar
You dont need to disconect the cluster. Just the battery. If the lights come back on then there is a problem that needs to be addrfessed to get the lights to go off
Old Aug 30, 2006 | 12:41 AM
victorvu's Avatar
yeah i already did i let the negative sit out for 5 mins and plugged it back in. and then i disconnect both +and- and still on.
Old Aug 30, 2006 | 12:53 AM
o2 sensor, warrantied to 70k
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
Rob144
Sep 21, 2015 08:18 AM
