VSA and /!\ lights on - I got codes too, please help
Old Jun 27, 2012 | 02:57 PM
dvallejo's Avatar
Hi everyone, it would be great if someone could help me out here. I'm getting both lights on after my car was towed. Its kinda embarrassing but my wife took my car keys and left me at home with spare keys that apparently didn't work (couldn't find my good spare keys). I attempted to turn the car on and the keys did not work. I towed it to the nearest auto shop and they confirmed these keys were not for this car even though they opened the doors, etc. I then got my good keys and was on my way...
Today, I took it in to a auto shop to read the codes and they managed to pull 25-1, 64-1, 83-1. Any idea what this means? I appreciate any input on these ... tried to search the forum with these codes but had no luck. Thanks!
Old Jun 28, 2012 | 06:00 PM
01tl4tl's Avatar
are those brake codes?
normal codes have letter number like P035
use google to search them
I would suspect damage to a wheel speed sensor wire during towing-tiedown
Old Jun 28, 2012 | 08:26 PM
Skirmich's Avatar
Those codes are ABS Related
Probably a Damaged ABS Sensor when they Towed.
Old Jun 28, 2012 | 09:16 PM
01tl4tl's Avatar
are we talking about the same part? a wheel speed sensor ~50$?
I know you can damage a wire doing a brake job wrong,,
the wire is small and vulnerable
Start with a visual inspection of each wheel
Test the ABS, at 35-45mph on slippery surface, and stand on brakes- what does it do?
work at all?, one wheel locks,,
Old Jun 29, 2012 | 10:45 AM
dvallejo's Avatar
Thank you everyone for your input, I did a quick search online and I got the below explanations on each code. The guy that pulled these felt pretty confident they were accurate Acura codes since they had the program for it.
25-1 Yaw rate sensor failure
64-1 Sensor supply voltage failure
83-1 ECM/PCM relation installation
I actually need new tires and took my car into the shop today - I'll report back, thanks!
Old Jun 29, 2012 | 01:34 PM
dvallejo's Avatar
Ok just got back the lights are still on and the Mechanic didn't find anything. I'm just gonna try to drive it for awhile and see if the lights turn off. Thanks again everyone and please feel free to drop any additional suggestions.
Old Jun 29, 2012 | 09:18 PM
01tl4tl's Avatar
pull the CLOCK fuse on passenger end of dash to reset the ECU and clear codes
those things have not failed- its false or misleading codes at the least
did you guy ck the speed sensor wires?
tow hook can snag one and tear it loose inside connector!
Old Jul 2, 2012 | 03:34 PM
dvallejo's Avatar
Pulled the fuse but it didn't reset. Is the reset instant? Lights are still on but maybe I need to drive more on it?
I dont know if the speed sensor wires have been checked. My mechanic didn't say anything about those. I think I may just take it into an Acura dealer and see what the problem is. I was just really trying to not pay the $117 diagnose fee. Thanks!
Old Jul 2, 2012 | 06:13 PM
01tl4tl's Avatar
dont go to acura yet
look up a brake specialty shop in phone book,,,
they can fix it for what acura wants just to guess whats wrong!
then charge more to fix it! what a scam
ask your mechanic was was chd--speed sensor wires or not--wtf did he actually do?
vehicle was towed--there are certain areas to look for damage from that
the clock fuse resets ECU for all engine functions- may not clear ABS codes
Possible the brake shop needs to use special ABS code scanner to reset after fix
most regular scanners wont give up real ABS codes
Old Jul 2, 2012 | 06:17 PM
dvallejo's Avatar
Good suggestion, I'll call around and see if someone else can see my car. Thanks.
Old Sep 2, 2015 | 09:55 PM
Matchu9912's Avatar
Did u ever figure your problem I'm experiencing the same exact problems
Old Sep 12, 2015 | 09:54 AM
01tl4tl's Avatar
try a more current thread than 2012 for answers
Have you got the codes read? must start there- then your exact symptoms
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
Big mo
4G TL Problems & Fixes
Sep 12, 2015 07:22 AM
bryan zaragoza
Sep 8, 2015 12:28 AM
Stu2414
Aug 30, 2015 07:30 PM
