Vapor Lock??
Old Aug 28, 2011 | 10:39 PM
LAMike240's Avatar
Vapor Lock??
So today in So Cal, it was about 100 degrees out. I did a bit of driving, not much. 20 miles tops. Took kid to dinner, 20 minutes later, came out to leave.
Car cranked and cranked, no start. Seemed like no fuel. Did this 4 or 5 times. Finally, I thought, ok, vapor lock?
Loosened up the fuel cap and the car fired right up.
It's a 2003 TL-S with 195k on the clock. I've owned the car since 06 and have never seen this problem over many hot summers here in LA.
Is this a one time incident, or is it a symptom of something more I should have looked at?
Thanks all.
Mike
Old Aug 29, 2011 | 12:46 AM
01tl4tl's Avatar
time for spark plugs? gas cap seal condition?
Old Aug 29, 2011 | 05:24 AM
Skirmich's Avatar
Gas Pump? Seems wierd, Usually Gas Vapor Related issues will drop a MIL (Check Engine).
Old Aug 29, 2011 | 10:07 AM
fsttyms1's Avatar
Did you see the green key blinking or light up on the inst cluster while trying to start the car?
Old Aug 29, 2011 | 05:40 PM
LAMike240's Avatar
Guys,
No Check engine light and I didn't pay attention to the green key. What would a flashing green key mean?
No symptoms today.
Thanks,
Old Aug 29, 2011 | 06:10 PM
fsttyms1's Avatar
Originally Posted by LAMike240
Guys,
No symptoms today.
Thanks,
If it wasnt it means the Immobilizer isnt reading the key. (which you would get similar symptoms that you described of the motor just cranking)
MrHeeltoe
20
Feb 23, 2023 01:54 PM
soupi
14
Nov 15, 2015 11:15 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
DementiaPhuro
Sep 29, 2015 05:31 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
