Valve adjustment...
Old Jan 12, 2010 | 07:32 PM
AznHonda's Avatar
Valve adjustment...
Have any one done a Valve adjustment by yourself? and is it hard to do it by yourself? Also is it hard to replace the valve cover gasket and do you need to replace the manifold gasket also?
Old Jan 12, 2010 | 07:42 PM
Srb's Avatar
Srb
00 ssm
It's not too hard if you go step by step. Helms manual helps. There's also a diy on here. The rear exhausts are a bit of a pain to get to but the rest are easy. You dont need to replace the manifold gasket. I didnt replace the valve cover gasket either but its not hard to replace, there's a groove in the valve cover where the gasket sits.
Old Jan 12, 2010 | 07:54 PM
AznHonda's Avatar
I have to replace the valve cover gasket because I'm leaking oil there, so I thought doing the valve adjustment at the same time.
Old Jan 12, 2010 | 09:54 PM
acutee's Avatar
DIY Valve Adjustment by Phee
Here you go:
https://acurazine.com/forums/showthr...adjustment+diy
Old Jan 13, 2010 | 11:35 AM
AznHonda's Avatar
Thank you!.. I also want to confirm this if I have a 3.2L engine do I need to do a valve adjustment? because I read somewhere that if your tl is 3.2 L it does not need a valve adjustment because the rocket arm or something like that.
Old Jan 13, 2010 | 04:47 PM
fsttyms1's Avatar
They still need them.
Old Jan 13, 2010 | 09:50 PM
totaledTL's Avatar
Rocket arm-
Old Jan 26, 2010 | 01:25 PM
smartypants's Avatar
.....LOL.....rocket arm.......that should be rocker arm....which TL's don't even have ! LOL !
Old Jan 26, 2010 | 03:30 PM
TLer trash's Avatar
Ahhhh....... actually they do have rocker arms.
fifer16
1G RL (1996-2004)
Nov 22, 2024 07:07 PM
Mike734
Dec 10, 2021 01:25 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
prbori
Sep 27, 2015 01:37 AM
MilanoRedDashR
Sep 24, 2015 11:04 PM
