Vacuum Leak!
Old Jan 7, 2012 | 08:37 AM
deepconcentratn's Avatar
Vacuum Leak!
Check Engine Light came on. I took it to Advance and they said it was a vacuum leak. I should have gotten a code but thats what he told me. Where are the most common vacuum leaks?
Here is the tricky part. I need to get my car emissions before the 8th. Why? If you get your car emissions after your birth date, they charge you a late fee. I don't want to pay a late fee. I need help. Got any idea where that look could be. I look and looked...can't find nothing. I don't hear any strange hissing noise or anything out of the ordinary. Any suggestions?
Old Jan 7, 2012 | 11:05 AM
01tl4tl's Avatar
we need the codes
its probably related to the egr system,,have you cleaned the port and passage system inside the intake manifold yet? must remove intake and clean, 2 hour diy at casual pace
you removed the plastic engine cover and looked at the vac lines there-around the throttle body
Have you seafoamed it?
Old Jan 7, 2012 | 11:07 AM
01tl4tl's Avatar
we dont have a common vac leak---EXCEPT!! the front and rear motor mounts
are vac boosted--failure of one will cause a vac leak you cant hear or see
ck those out- look for signs of oil drip from mount and apply a vac pump/guage to test
Old Jan 7, 2012 | 04:17 PM
I looked everywhere. I took off the shield and checked everywhere. I can't anything. I haven't cleaned the ports. Do you think that would do it? I haven't seafoamed it
Old Jan 8, 2012 | 09:07 AM
totaledTL's Avatar
Need code(s)- probl. will save time to rescan it rather than just crap shooting.
Mike734
Dec 10, 2021 01:25 PM
IBankMouse
Jun 13, 2020 12:53 PM
Avenger411
Oct 11, 2015 03:53 PM
steve
Sep 30, 2015 09:23 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
