UR-PULLY Trouble
Old Sep 15, 2012 | 01:54 AM
Kulunu06's Avatar
UR-PULLY Trouble
Hey guys, so I changed my pully with a UR stock diameter one and a day later my ac is making this annoying noise it's driving me nuts and it only happens when the ac is on it starts making this high pitch noise anyone have any idea how to fix this problem?
Old Sep 15, 2012 | 09:08 AM
MilwaukeeDave's Avatar
Make sure your belt is seated properly and is not over tightened.
Old Sep 15, 2012 | 10:41 AM
3.2TLc's Avatar
Could be a worn idler or accessory pulley bearing going bad.
Old Sep 15, 2012 | 11:18 AM
01tl4tl's Avatar
was the pulley nut torque set to 182 foot pounds?
with what method,,so you know it really is set, not just what an air gun would do?
if not it maybe sitting out just enough to strain the belt alignment
iirc a different brand belt works best with UR, the edges are differant than stock,
ck UR site,,gatorback/goodyear belt maybe?
but there is a preferred brand..ck diy may be there
ac belt tensioner always a possible, but usually a grumbling sound
ck with mechanics stethascope or long screwdriver
Old Sep 15, 2012 | 11:21 AM
Kulunu06's Avatar
Thanks for the tips guys im gonna go check with my mechanic today I think he over tightened the belt..let's hope that's it
Old Sep 15, 2012 | 11:35 AM
HEAVY_RL's Avatar
I LuLed when I read "I changed my pulley" then I read "my mechanic over tightened the belt"
If the mechanic put it in, take it back.
Old Sep 15, 2012 | 11:38 AM
My stock belt is working great w UR pulley set. I have the newest revisions of the pulleys.
Old Sep 15, 2012 | 12:16 PM
Bearcat94's Avatar
AZ Community Team
but there is a preferred brand..ck diy may be there....
Gates Belts preferred, iirc. The Gatorback (supposedly?) has the different edge. Double check the UR site for their recommendation.
Old Sep 15, 2012 | 09:04 PM
01tl4tl's Avatar
do I get partial credit for some of the right letters?
Old Sep 16, 2012 | 02:55 AM
Kulunu06's Avatar
Lol well I thought it had something to do with the pully when I made the post but I was wrong so I went to the mechanic that installed it he said its the ac clutch I called my friend and he told me get some water and while the engine is running pour it on the pully if the noise goes away its your belt and it was my belt I just needed a new belt I changed it the noise went away. Problem solved
Old Sep 16, 2012 | 10:26 AM
Never pour water on a hot running engine. You can warp or crack any very hot parts by doing so. But glad your problem is fixed. Next time buy a can of belt dressing and spray that on there. If the noise stops then change the belt.
Old Sep 16, 2012 | 10:30 AM
Bearcat94's Avatar
AZ Community Team
Haha. Tom you get ALL the credit.
Old Sep 16, 2012 | 12:19 PM
Kulunu06's Avatar
Yeah it wasn't hot the engine was off for a while I was letting it cool off first before I did it. But me to glad I didn't have to change the ac clutch. Ha
08KBP_VA
Oct 22, 2019 01:55 PM
baelim
May 10, 2018 09:53 AM
Jinkazetsukai
Nov 21, 2015 05:28 PM
CWOVette
1/2G MDX (2001-2013)
Sep 27, 2015 02:29 AM
