Turning Signals
Old Aug 5, 2013 | 01:37 PM
tjkazai's Avatar
2002 Acura TL
Arrow Turning Signals
I've got a question, recently when I changed my car to JDM front the front 'parking lights' or the amber on the side used to flash when signaling.. but now the lights just turn on but they don't flash? can someone help? would it be a fuse? wiring? the bulb isn't dead cause the parking lights still work, thanks a lot, oh ya the back tail light signals do work but not the front!
Old Aug 5, 2013 | 03:32 PM
tjkazai's Avatar
2002 Acura TL
it can't be flasher relay because I just changed it recently.
Old Aug 14, 2013 | 11:56 AM
tjkazai's Avatar
2002 Acura TL
nobody knows?
Old Aug 14, 2013 | 05:01 PM
3.2TLc's Avatar
If everything was working perfectly well prior to the front "JDM" swap, then apparently it's either with the wiring connector, bulb, or ground. Compare the parts . The bulbs must have the extra filament for the turn signal. Could be why only the parking lamp lights up ? Everything else should be ok if the rear turn signal lights work along with the taillamps/brakes.
SidhuSaaB
May 30, 2020 12:40 AM
navtool.com
31
Nov 16, 2015 08:30 PM
ROSSARONIE
Oct 2, 2015 11:46 AM
Greengecko
Sep 16, 2015 08:19 PM
