Trunk Drilling
Trunk Drilling
has anyone drilled straight through the floor and into the metal in the trunk to mount down your sub box and if so is there any gas llines or anything near?
your joking right? I have NEVER had a box heavy enough to stay put with my driving.
OP. remove the back seat and attach it to the cross bracing. That way you wont have to drill thru the floor of the car.
Another thing you can do to check is drill a very small hole where you intend to mount anything & push a thin stiff wire through the hole to check for obstructions & clearance depth. Use a stop on the bit & do not push hard so the bit won't go any further than necessary. Easy to seal a very small hole if necessary.
2003 TL-p
right now i have two big cardboard boxes in my trunk to keep my subs from flying all over the place. i dont brake when i go around turns so i get better gas mileage
i bet u also think if u get up to speed fast and coast that saves gas too. The mind of an post adolecent, is invincible and impervious to good suggestions, stuck in its own ways to be later taught a lesson by nature or law enforcement
08_UA7_Gr33k
02-11-2016 02:17 PM
08_UA7_Gr33k
09-27-2015 01:56 PM
justin.w13.walker
09-22-2015 02:21 PM
