Engine failure
Old Sep 21, 2009 | 03:29 PM
medallion's Avatar
4th Gear
Engine failure
Hi,
I bought an Acura at 143K miles. The engine was working like a clock.
Yeterday, all of a sudden, while driving on the highway, there was a tremendous noise. So, I stopped and towed the car to the mechanic. After the incident, the low oil light is always on.
Today, my mechanic told me that the engine died He told me that oil is full, but there are metal pieces in the oil. So, the pistons and valves do not work properly.
He mentioned possible to reasons: Either timing belt slipped or oil pump did not work.
He is talking about rebuilding the engine or getting one from junk yard.
Any idea, experince, cost estimate would be greatly appreciated.
Old Sep 21, 2009 | 04:49 PM
wise2k's Avatar
Ouch I suspect the timing belt based on your 143k miles, coz some people even on this forum still drive on original timing belts past that mileage when it is recommended that it be changed at 105k miles or 7 years whichever is earlier.
Previous owner probably sold it because it is a 'pricey' maintanance task and messed you up in the process.
A used engine from a junk yard would probably be your cheapest, easiest, and more reliable fix
Old Sep 21, 2009 | 06:18 PM
StonedCL's Avatar
B A N N E D
From: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
www.car-parts.com
They search junk yard throught the country!
You can find a good type-s engine for under 1K if u look around!
Old Sep 21, 2009 | 06:20 PM
StonedCL's Avatar
B A N N E D
I just searched that website and found about 10 Type-S engines from $500-$600 less then 20 miles from my zip code!
Old Sep 21, 2009 | 09:44 PM
yoyoball's Avatar
what a nice site, great find
Old Sep 22, 2009 | 10:15 AM
medallion's Avatar
4th Gear
Thank you very much for your responses. I searched car-parts.com and found from $200-$850. I do not know which one is better.
Old Sep 22, 2009 | 10:25 AM
medallion's Avatar
4th Gear
Originally Posted by StonedCL
www.car-parts.com
Can I put type-s if it is not originally type-s? How can I transport the engine? How heavy is it?
Old Sep 22, 2009 | 02:39 PM
StonedCL's Avatar
B A N N E D
The engine is a few hundred lbs.. The non s and s weight about the same give or take a few lbs the transmissions are the same but you might need a new CPU im not sure what else need to be done ..u might wanna post in the TL section.. If u have a pick up or SUV Im sure the junk will help u load it up and the guy thats putting it in your car will help take it off but it IS HEAVY..
maybee 400 LBs ???
Old Sep 22, 2009 | 07:20 PM
nhn23's Avatar
I live in
"clocks" sometimes stop working too ya know.
Old Sep 22, 2009 | 08:30 PM
phee's Avatar
I got the Shifts
buy a motor. a rebuild is more expensive. and this time, change the timing belt on the motor.
rules of buying a honda
new t belt
new water pump
valve adjust
tranny drain and fill (not a vacuum flush from a 10 minute place)
check balljoints and bearings
oil change
compression check
Old Sep 23, 2009 | 11:35 AM
medallion's Avatar
4th Gear
Thank you guys, I will buy an engine from junk yard.
SidhuSaaB
May 30, 2020 12:40 AM
Pham Alvan
Mar 16, 2016 09:17 AM
joflewbyu2
Oct 8, 2015 11:16 AM
ROSSARONIE
Oct 2, 2015 11:46 AM
STL TL-S
Sep 23, 2015 08:52 PM
