TRasmission and overheating
Old Mar 17, 2007 | 11:58 PM
zerep6's Avatar
I recently had a problem where the engine got really hot. The tl wouldnt start I let it cool down for an hour and started right up I checked the trasmission fluid it smelled burned. I cleaned the fuel injectors, changed the trasmission fluid, changed the power steering. The trasmission feels the same but the temperature.....When Im in a light at full stop the temperatre rises more than half the way. But when I accelarate the engine in neutral or when I put drive and drive around the temperature lowers to its normal position. What shlud I get checked
Old Mar 18, 2007 | 12:19 AM
Blazin_TL's Avatar
Registered User
transmission has nothing to do with engine overheating
did you check the coolant level? do your fans go on?
it could be a number of things like thermostat, fan switch etc.
Old Mar 18, 2007 | 09:27 AM
pixrob's Avatar
Also check to see that nothing is blocking the airflow to the radiator. Seems simple but look what happens when a hot dog wrapper gets caught on the front of a NASCAR race car.
Anybody here use WaterWetter on their TLs?
Old Mar 18, 2007 | 10:31 AM
sbuswell's Avatar
I need 2 more gears
I would change your coolant. check the coolant level when your car is cool first. It very well may be low, if it's not then your thermostat is probably busted. fan switch is a possibility. once you check your coolant level if that it okay then start your car and let it run until it's completely warmed up and pop the hood and see if the fan comes on, if it doesn't then it's probably the fan switch that's bad. this has nothing to do with your tranny.
Old Mar 18, 2007 | 09:27 PM
zerep6's Avatar
The fans work. About the water wetters, I have a friend that has an evo and he used water wetters it was horrible. He told me that he recommended the red coolant Toyota uses.
Frathora
Sep 28, 2015 11:29 PM
NSolace
Sep 3, 2015 08:14 PM
NSolace
Sep 3, 2015 08:02 PM
CLConcept117
Apr 11, 2007 05:58 AM
Jezek
Jun 20, 2006 11:30 PM
