Trany problem/question.
Old Sep 25, 2011 | 04:39 PM
maxjoker99's Avatar
Hey everyone, i have 99 Tl @137k miles, i have a jerky transmission i saved some cash and i can get a new trany, also im asking if the trany from 2000 TL will fit my 99 TL and if i need to mess around with ECU to make it compatible or i can just drop it in?
Old Sep 25, 2011 | 05:41 PM
thewrangler99's Avatar
first of all try changing the trany fluid with atf dw-1. see if it helps... and forget 2000 tl trany because they are less reliable compared to 99 tl 4speed ones. if you have extra cash either do 6speed swap like our other members are doing right now!!!
Old Sep 25, 2011 | 08:21 PM
01tl4tl's Avatar
NO it wont bolt in, you are a 4 speed correct?
look into what honda 4 speed will fit- those are a good option
Old Sep 25, 2011 | 09:00 PM
my.daily'tl''s Avatar
Always Working In
Honda odyssey 99-01 will bolt right in but needs a hole drilled to work right.
Old Sep 25, 2011 | 11:46 PM
maxjoker99's Avatar
i would do that i have around 3g's saved how much would it cost me to swap in the 6sp manual( any tutorial or something cuz im a big azz noob im only 18).
Old Sep 26, 2011 | 09:07 AM
fsttyms1's Avatar
Since you are a big azz noob and only 18 i will help you. Use the search button, put in "6 speed" select 2nd gen TL and hit search. It will give you ALL sorts of info.
Old Sep 26, 2011 | 05:29 PM
maxjoker99's Avatar
i saw the ur post, its awesome, but u had put a J32A CL-S engine with a trany, my question is can i just get 6sp trany and a remapped ECU? and will it work with my original engine? sry if the questions are stupid.
Old Sep 26, 2011 | 07:10 PM
^ i saw a thread that's still active and that member swaped 04tl 6speed trans his 99tl with stock engine......
Old Sep 26, 2011 | 09:31 PM
fsttyms1's Avatar
Yes, it will bolt right up. NO you cant get a remapped ECU (no such thing or way to do it) You need to buy the Richie module.
Old Sep 28, 2011 | 12:35 AM
maxjoker99's Avatar
ok i had understood that if i do the trany swap only it will work but the engine will not make it to the end and its cheaper, if i do the engine swap with the trany it will cost me more but the end result will satisfy you more, my other question if I was to do the j32a2 engine swap with the trany what would be like the cost im looking at with labor?
Old Sep 28, 2011 | 11:42 AM
fsttyms1's Avatar
What do you mean the engine wont make it to the end??
I dont know. I havent seen anyone pay for someone to do it. Labor varies from shop to shop. If i had to guess im sure 2-5k depending on location and shop just for labor.
Old Sep 29, 2011 | 11:44 PM
maxjoker99's Avatar
well i read some post and the guy said that the engine will die sooner withe the 6sp than it would of with the original 4sp auto
Old Sep 30, 2011 | 08:38 AM
01tl4tl's Avatar
thats some made up info
Keep up the oil changes and water pump- timing belt replacement
adjust the valves and run it
200kmiles is nothing to these engines
fsttyms1 had a 2000 type P engine, and got a newer type S with the 6speed = 35 more engine hp
Old Sep 30, 2011 | 10:57 AM
maxjoker99's Avatar
ye i saw that post i dont have the moneys for the engine tho, plus this car became my daily driver after i roled my si hatch and i need this this car running since im a college student and i commute to school.
Old Sep 30, 2011 | 11:26 AM
fsttyms1's Avatar
I dont know where you possibly read that the motor would die sooner with the 6 speed as that is a bunch of false info. manual or auto wouldnt make the motor die sooner.
Oh, and You can find type-s motor s for 500 or so used
Pham Alvan
Mar 16, 2016 09:17 AM
Blue3.2TL
1G TL (1996-1998)
Oct 17, 2008 10:04 PM
truonghthe
Aug 31, 2008 06:09 PM
Elijah J
Feb 10, 2008 06:24 PM
Big Ped
Nov 24, 2001 03:49 PM
