Trany problem?
Old Aug 31, 2011 | 04:56 PM
maxjoker99's Avatar
Trany problem?
i got 99 TL 136k original miles, today i have noticed that my gear changes are a bit delayed and jerky especially in the turns, when accelerate slowly its smooth and seems normal but, for example when you wana scoot ahead quickly its delayed and jerky, i also noticed that my passenger axle need replacement maybe that has to do something with it, any advice what to do
thx ahead.
Old Aug 31, 2011 | 05:11 PM
my.daily'tl''s Avatar
Always Working In
Get your axle fixed.
When was the last time you changed the trans fluid?
Old Aug 31, 2011 | 05:18 PM
maxjoker99's Avatar
idk my dad gave me the car he said it was all good but im thinking that i will gonna get axle fixed tomorrow after work and also change the trans fluid, does the axle has anything to do with it tho?
Old Aug 31, 2011 | 06:19 PM
01tl4tl's Avatar
yes the axle is a main problem at this moment,,fix it and ck the color and smell of the trans fluid
the atf is not something most owners think to change,,even the best intentioned dads~
use Honda atf from the dealer, buy 4 qts..it will take almost 3.4
Old Aug 31, 2011 | 06:28 PM
maxjoker99's Avatar
ok ill do that and ill c what happens, and ill get back to you, thx for now
Old Sep 1, 2011 | 01:45 AM
dcjr's Avatar
remember to manually drain your tran fluid. dont have the system flushed TL Tranny's hate being flushed.
Old Sep 1, 2011 | 11:05 AM
ou sig's Avatar
Boomer SOONER
I got both of my axles replaced and it did help the shifting some for sure - not 100% better but it was noticeable. both of my axles were very bad
Old Sep 1, 2011 | 07:24 PM
maxjoker99's Avatar
ok so i took the axle off and i notice that my whole brake disc was covered in oily substance and some of it was on the splash guard, i put my car on axle stance and some bricks right axle is out i have the new one comming in tomorrow so ill pick it up and install and change the trany fluid and ill get back you with a result. thxz
Old Sep 2, 2011 | 10:07 AM
01tl4tl's Avatar
that was the cv bearing grease splattered on the disc shield
SidhuSaaB
May 30, 2020 12:40 AM
Pham Alvan
Mar 16, 2016 09:17 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
