Transmission solved! 2006-2007 accord tranny works great!
#81
Check out the "Regional" sub-forum for your particular area.
Call around to your local independent tranny shops and also any import "tuner" shops.
#82
I found a shop that would rebuild IF they need to. He said he'd like to diagnose it before we get into replacing the unit. With that said, he said if it's a "direct" bolt on, he'd take a shot at it but needs the 4 "digit" code. An earlier post said BAYA or MAYA, would that be correct? TIA!
#83
I had brother in law used to drive also Odyssey, it pissed him off after tranny failed and he could no longer back up at parking lot one time. He sold it afterward.
#84
Mine is working find but in case if it fails, if anyone has done in bay area (san francisco, san jose) please let me know. I might be also travel to some distances may be LA, Oregon, Nevada.
#85
For honda I see baya Maya
For acura I see b7wa but for some reason not seeing bawa.
I soon screenshot my top box
https://www.dropbox.com/sh/q9c5abfd1cjvn4x/v1oQPUm2wY
MrChanh (12-08-2013)
#86
For a trans swap, the 05-06 oddy trans is what you would be looking for. My mentality for putting an 05 oddy trans in my 00 tl was: sure the 4th gear ratio on the Accord trans is a little taller, but I figured that the accord was probably driven pretty hard too. Odyssey is a minivan, prolly not driven as hard and I'll drop into 5th at a higher speed. So far its been 1 year and 30k and it still hits 150, yeah it takes 2 miles to get there from 75 but 150 is 150 and the trans feels like its new.
#87
My trans just starting giving out on me Monday. I would really like to do the swap. This is the 4th time it's died on me and the first 3 rebuilds were under warranty from the shop that did the rebuild, but they won't cover it this time and I don't see the point in dropping $2500 to have it break again in another 6-8 months. I do a lot of work on my car, but this is a bit over my head, so I would bring it in once I found the trans. Where would be good places to look for one?
#88
#90
is the range switch have to be the one from Honda? top solenoid pack also from honda? would you happen to have part number?
#91
You have to swap over the range switch from your old TL tranny. I wouldn't bother with replacing the solenoids. But if you really want to, I think he is referring to the linear solenoids which will cost you about $250
2007 Honda ACCORD SEDAN EX (V6 NAVI) SOLENOID ASSY., LINEAR - (28250-P6H-024) - Honda Parts Online : Honda Parts Unlimited | Genuine OEM Honda Parts & Accessories
frankjnjr (07-14-2017)
#94
2007 Honda ACCORD SEDAN EX (V6 NAVI) SOLENOID ASSY., LINEAR - (28250-P6H-024) - Honda Parts Online : Honda Parts Unlimited Genuine OEM Honda Parts & Accessories
#96
Is this still going?
Well we have had the 2006-2007 Honda Accord transmission in my TL type S 2002 acura for a week now and works great! My transmission shop said it went smoothly, did the transfer of the range switch and the oil cooler filter assembly from the TL tranny as mentioned on other posts. I found a used 64K miles tranny on a 2007 Accord, got it for 750.00, and the labor and transmission oil from shop was $495.00, so at approx 1250.00 I am happy with the situation. I hope that the technology in the Honda accord transmission has had some improvements that will get a more durable transmission than the Acura problem filled Generation 2 trannys.
If interested, the shop that did it is in Danville Illinois, and is a second generation shop named Hank's Transmissions, and their number is 217-443-3091, ask for owner Hank. They have been in business for over 30 years and have a great reputation in central Illinois.
#97
#98
Please help
I have a 2007 Honda Accord tranny for my 2000 Acura TL. We've found that all hooks up except the power steering pump. There is a place on the new tranny for it but there is a plate over it. Can we pull the plate off and put it in there? Please help I'm excited about the swap and for this to be the last time.
#99
the power steering pump doesn't attach to the tranny
#100
Insane TL owner
will any other auto gearboxes work on 2Gs? I have a 2000 TL myself, I'm the 3rd owner, and the car is, from what I could gather, on it's 4th transmission. I wanted to know if I could go crazy and swap in a much newer trans, like one from a TLX.
#102
Which specific tranny
I’m looking to purchase a tranny here even if not here which specific tranny would I need for example there is Japan built US built Mexico Built 2.4 L 3.0 L etc etc according to this site
https://automotix.net/usedtransmissi...487&seq_num=16
#103
Greetings I have a 2003 Acura TL S with 214,000 miles. I need to know which specific 07 Honda Accord tranny will fit best for my car like there’s different ones according to a site to choose from 2.4L,3.0L Japan built, US built etc.
#104
run a search for "AV6"
mada51589
05-03-2022 08:54 PM
tman570
06-11-2019 07:56 AM
