Transmission options 2003 TL Type S
Old Jan 21, 2013 | 06:54 PM
Powashiftin's Avatar
Brand new to these forums and see some have swapped out accord or odyssey transmissions. Can some one tell me what options I have for my 2003 TL type s?
Old Jan 21, 2013 | 08:42 PM
LiveFive's Avatar
Some people have swapped it out with a 06 accord transmission and had great success. I tried to swap it out too with an 06 accord tranny but the transmission speed sensor wouldn't bolt up to it so I had to stick with a 02 TL tranny. It's shifting like butter but the swap can be done with little to no modification.
Old Jan 21, 2013 | 08:58 PM
Stephen00TL's Avatar
Chapter Leader (Southeast Region)
Get an 06-07 Honda accord v6 transmission. Try to get one with low miles and all you have to do is swap out the entire oil cooler warmer assembly, range switch, and the small 3&4 gear pressure switch harness.
Old Jan 21, 2013 | 08:59 PM
Man you should have kept the accord transmission you just delete that speed sensor by looping the power steering rack with a rubber hose.
Old Jan 22, 2013 | 03:19 AM
32tl00tuneacura's Avatar
The bypass looks like this
Old Jan 24, 2013 | 07:08 PM
Thanks. Getting the tranny rebuilt.
Old Jan 25, 2013 | 07:25 AM
3.2TLc's Avatar
rebuilding tranny...........
Hey Powashiftin.....keep us posted as to how things go with the rebuild !
Old Jan 25, 2013 | 08:51 AM
tightnight's Avatar
which angle view and which pipe is the ps line? thanks!
Old Jan 25, 2013 | 03:10 PM
MilwaukeeDave's Avatar
I'm guessing its the rubber hose in a U shape pretty much dead center. Correct me if I'm wrong.
Old Jan 25, 2013 | 05:19 PM
Tranny rebuilt with 3 year 50,000 mile warranty for just under $3k
Old Jan 25, 2013 | 07:21 PM
tightnight's Avatar
which shop you will go, national chain or local?
Old Jan 25, 2013 | 10:03 PM
fsttyms1's Avatar
Also anyone can do this with the auto for a firmer steering feel.
Old Jan 25, 2013 | 10:23 PM
Yep anybody can do it but you have to do it when swapping the transmission with a different model than ours. There is not a spot on the new transmission for the power steering speed sensor. I have driven with mine like that for 7,000 miles and I love the way it feels.
Old Jan 26, 2013 | 01:30 AM
B.TL's Avatar
That is an excellent deal.
Mine? $3500 3/36,000 and they aren't some half *ssed shop either.
Old Jan 27, 2013 | 09:27 PM
Yeah, the picture is from the front of the car and it is the U shapped hose. Its a little trick because there is a bit of difference in the two pipe diameters. But I found a flexable hose with an internal diameter roughly the size of the smaller pipe, and then worked it around the bigger one. Just make sure you have good hose clamps .
Old Jan 27, 2013 | 09:28 PM
I do like the feel of the steering the way it is now. It doesn't feel a lot different but its more firm at slow speeds.
Old Jan 28, 2013 | 12:40 AM
tightnight's Avatar
which tranny you used, accord or oddyssey?
Old Jan 28, 2013 | 06:26 AM
fsttyms1's Avatar
I have driven mine like that for 200k miles. I love the way it feels. Much more weighted and better feel and feedback.
Old Jan 28, 2013 | 09:04 AM
05 oddyssey
Old Jan 28, 2013 | 08:09 PM
Transmission repaired! Just bought the car too. Feels great.
1fatcrxnem1
22
Jun 1, 2018 01:23 AM
james357
Feb 13, 2016 02:37 PM
BlkTxAcuraTypeS
Oct 18, 2015 08:05 PM
Allen_442
Sep 8, 2015 06:01 PM
