Ticking sound
Old Aug 7, 2017 | 11:22 PM
Mr. Memolo's Avatar
Ticking sound
Aight so i got a 2000 tl and there is a ticking sound coming from under the hood on the driver side right by the firewall. Only when the car is in idle. The car has 275,000 miles and has been pretty strong. I fix what i can when i can and try to maintain it as much as possible. Regular oil changes and tranny flushes wit dw1 only. And pretty much all oem parts. Anyone got any suggestions or thoughts on it. Thanks
Old Aug 7, 2017 | 11:27 PM
Karanx7's Avatar
Unregistered Member
It's the purge control solenoid valve. You can ignore it, or replace it if the ticking bothers you.
Old Aug 7, 2017 | 11:50 PM
Mr. Memolo's Avatar
It really dont bother me none. I just wanted to make sure its not something i need to worry about. Thanks
Old Jun 15, 2018 | 10:49 PM
Puffyacura's Avatar
7th Gear
Elaborate?pls?
Old Jun 16, 2018 | 05:46 AM
Iggy's Avatar
Originally Posted by Puffyacura
Elaborate?pls?
Not much to elaborate on. With age they start to tick but still work just fine 99% of the time. Like anything else mechanical they can fail, but will be accompanied with an EVAP code.
Old Feb 12, 2020 | 02:55 PM
ryancarbo's Avatar
4th Gear
Reviving this
Hi there,
Im also having a ticking sound. It is definitely coming from my purge solenoid - I can feel the ticking when I put my finger on it! I've replaced it once already and honestly, it might be worse now. I'm able to hear it quite audibly when idling with windows up inside the vehicle.
I used: https://www.oreillyauto.com/detail/b...solenoid&pos=0
Should I try and replace it again? Could that ticking be related to something else?
Here is a video taken this morning. Sound up please:
