throttle body cables
Old Dec 30, 2005 | 04:39 PM
tnewyes's Avatar
Will someone help me please? I'm in the process of removing my throttle body. I almost have everything unplugged and unbolted. I'm not 100% sure on how to disconnect the throttle body cables(if the cables run through it how can you seperate it?). I'm also having a tough time removing the medium size hose from the back of the intake. Can someone offer some advice?
Old Dec 30, 2005 | 04:48 PM
loud_whispers's Avatar
just loosen the 10mm nut, release tension on the cable by opening the butterfly valve and unwrapping the cable. its as simple as that. Install the reverse order of removal.
Old Dec 30, 2005 | 05:41 PM
tnewyes's Avatar
is it just 1 10mm nut? I'm really lost.
Old Dec 30, 2005 | 07:58 PM
yes, just loosen it..
Old Dec 30, 2005 | 11:44 PM
PenancE's Avatar
dont take out the nut, its just a waste. push in the cable with ur hands, like inward, when u open the TB wit the butterfly open, and u can see a oval cylinder slot, and manover the wire wit that metal piece thru it.
Old Jan 4, 2006 | 02:13 PM
it's better for him to loosen the nuts so he can actually see what he's removing so he can install it correctly on the new one. It's his first time doing this.
He's in no rush.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Jinkazetsukai
Nov 21, 2015 05:28 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
Username 0
2G TSX Performance Parts & Modifications
23
Sep 28, 2015 09:09 AM
