There's a frog trapped in the drivers side suspension.....
Hi All :
Anyone had a creak/moan that happens when the suspension travels up and down ? I can even reproduce it by bouncing up and down on the fender. Is there a part I can quickly lubricate without taking off the wheel ? (I know, faint hope...)
On a related note, earlier I had the car in for a oil change at one of those cheap quickie places and they told me the Acura has no suspension grease points. Is this true ?
Thanks to all once again for your help.
smartypants
smartypants
Mine has a frog too. I lubed the bushings but that didn't fix the problem. My shocks are like new and I took them out and they are still good. Not sure where else to find. I checked every joint and they are good, and all nuts and bolts are tight.
might depend on the material used for the bushings - through other sources, I've heard complaints about urethane bushings being squeaky in applications where they twist, and neoprene is better - maybe a guru here would know what Honda used......(?)
My car has had this noise for about 5 years - only when it's cold - it doesn't do it when you push on the suspension. I assumed its the springs "creaking" because of the cold temp outside.
Unless you're talking about the frog noise you get a few seconds after you put the car into drive or reverse.......i still haven't figured out what that one is, but mine has been doing that for over 9 years.
When this noise happens it runs the ABS for about a sec.
rockyboy
Aug 4, 2024 10:35 AM
BoricuaTL
Apr 8, 2016 01:08 PM
sockr1
Oct 1, 2015 01:31 AM
