A/T gear position console light (2003 TL-P)
I did a search but nothing come up. This light is for the gear shift position at the center console and it is not working. I think it is the light bulb. Has anyone changed this bulb before? I never changed it so I need some help in getting at the bulb. Thank in advance.
2006 NBP TL MT6/ 02TL-S
Go to this link-it's pretty easy
http://www.acuraautomotiveparts.org/...s=&view=normal
There is a bulb. It is part #1 on this diagram.
Stick a small flat screwdriver under the edge of the plastic trim piece surrounding the gear shift area on the console. (part #22) Gently pop that up and off & remove it.
Unscrew the gear shift knob.
Then pop up & off the plastic piece that has the slot for the shift lever and the cut-outs for the P-R-N-D-#-2-1. You should be able to see and get at the bulb from there.
I had tried to unscrew the shift knob but it is very tight. I do not want to use too much force as I scare I will break something. Is there any set screw or just need to be turn harder. Thanks.
There is NO screw. Just twist really hard counter clockwise, it will come off.
Soul_Deamon
4G TL Problems & Fixes
11-02-2015 04:32 PM
HeloDown
09-08-2015 06:51 PM
