Sunroof issues
Old Jun 17, 2008 | 09:01 PM
Zapatista77's Avatar
4th Gear
Sunroof issues
My sunroof for some reason will not go back down to its original position. I noticed the fuse was blown so I replaced, the fuse blew again, try one more time to be sure, and sure enough it blew...I have a 03 with about 78,000 miles, should I take it to the dealer and have them fix it under warranty? Is my warranty still valid? I did some searching and I'm pretty sure its an a shorted wire, but I just would like to be sure.
Thanks everyone.
Old Jun 17, 2008 | 09:14 PM
Rajca's Avatar
wham bam thank you ma'am
but the sunroof moves, right? check to make sure that their is noting in the tracks.
Old Jun 17, 2008 | 09:27 PM
4th Gear
The sunroof does not move at all, and every time I try to move it, a fuse blows..
Old Jun 17, 2008 | 09:34 PM
4th Gear
Old Jun 18, 2008 | 01:32 AM
01tl4tl's Avatar
unless you got a special 100,000 warranty-acura CPO used car type warranty,
the regular one is long since past.
Blowing fuses is a bad ground or overload because the track is stuck- sometimes the screws get loose and need to be checked every year- but no one knows to!
Old Jun 18, 2008 | 01:33 AM
01tl4tl's Avatar
what happens when you use the manual tool- that z shaped thing stored in with the car jack is the tool
snorf
Nov 4, 2019 06:44 AM
Frathora
Sep 28, 2015 11:29 PM
rockyboy
Sep 23, 2015 12:02 AM
carz0159
Sep 20, 2015 06:11 PM
iRaw
ILX Photograph Gallery
Sep 10, 2015 12:29 AM
