Stutter during ignition
Old Jan 31, 2009 | 07:21 PM
SLushhYYY's Avatar
Keep It Simple in
When I turn my car on it feels as if the engine is shaking....The RPMs go below 500 and the car acts as if its going to die. The TCS light comes on for a while...and if I rev the engine all the lights come on and the car dies.When i add gas and drive away, the problem seems to go away. With smooth shifting after I dont think the problem is the tranny. I would think its either a cause of my broken motor mounts, or m ignition switch. Can anyone help PLEASE!!!!!!
Old Jan 31, 2009 | 08:39 PM
`ill*tl's Avatar
Most likely the ignition.. when you start your car, jiggle your keys inside the ignition and see if that does anything. Also, I had somewhat a similar issue that was solved by simply cleaning my fuel injectors.
Old Feb 1, 2009 | 02:07 AM
SLushhYYY's Avatar
Keep It Simple in
^^I just seafoamed my car 2 months ago......I geuss ill just do the gas tank this time
Old Feb 1, 2009 | 03:38 AM
thinhthan's Avatar
would that bg 44k stuff help?
Old Feb 1, 2009 | 08:16 AM
fsttyms1's Avatar
I dont think its the ignition. Bring it to a place that can read codes and see if one comes up. Clean your throttle body, EGR ports, and IACV
Old Feb 1, 2009 | 10:18 PM
SLushhYYY's Avatar
Keep It Simple in
The thing is, is that it only happens when I start up my car when its parked on a hill.....
Old Feb 3, 2009 | 05:24 PM
SLushhYYY's Avatar
Keep It Simple in
Now its fine...but when i leave my car off in the sun and come back to turn it on. It wont turn on. It tries and tries but it wont turn on unless i give it some gas. Is this the ignition switch?Oil Change? Timing belt? Spark Plugs?
Old Mar 31, 2009 | 02:27 PM
WhiteNite's Avatar
5th Gear
Is there a site somewhere that shows/tells how to Seafoam the TB's EGR ports and IACV?
Old Mar 31, 2009 | 06:11 PM
SLushhYYY's Avatar
Keep It Simple in
^^ www.acurazine.com
search!!!!!!!!!!
Old Mar 31, 2009 | 07:18 PM
Eddystone's Avatar
I have the same problem, I cleaned the IACV, EGR, and throttle body. And still have the problem. It only happens sometimes and I dont know when. I am still looking for a fix.
Old Mar 31, 2009 | 08:03 PM
3.2TLc's Avatar
Fuel pump relay. Worked for me !
Acura604
20
Aug 5, 2017 12:55 AM
ExcelerateRep
Oct 14, 2015 08:20 AM
MilanoRedDashR
Oct 8, 2015 10:30 AM
malvothegreat
Sep 29, 2015 12:38 AM
h22lude
Sep 27, 2015 06:22 PM
