studdering than shuts off
Old Feb 11, 2010 | 04:54 PM
thinhthan's Avatar
today i got into my car from getting a hair cut and when i started it started than started studdering and idling really low to the point it just shuts off. ill give it gas and the rpm will go up than do the same thing. ill like have to just throw it in drive and drive than it will stop. its been happen a couple times now. iono what it could be
Old Feb 11, 2010 | 07:59 PM
Rajca's Avatar
wham bam thank you ma'am
vacuum leak. check all ur hoses
Old Feb 11, 2010 | 10:27 PM
totaledTL's Avatar
IACV? EGR port?
Old Feb 12, 2010 | 12:45 AM
thinhthan's Avatar
i havent checked the vacuums yet but i cleaned the egr like 6 months ago and i havent clean the iacv.
Old Feb 12, 2010 | 11:54 AM
thinhthan's Avatar
and it only happens like once a week so iono if i could be a vac cause if it was shouldnt it happen all the time
Old Feb 17, 2010 | 01:28 AM
OutkastSL's Avatar
i have the same problem and i think it's the iacv...gonna try take it out and clean it with some brake clean. i'll let you know how it goes.
Old Feb 17, 2010 | 11:16 AM
rcb2000's Avatar
yes vaccum leaks don't come and go usually but can if it is occuring while hot only, if the car is cold and it does it and then stops that's not a vaccum leak and most likely IAC causing the problem.
If it happens after it's been driven and got hot then sits 10-15 minutes and it occurs then it could be a vaccum leak. Parts are expanding from the heat and creating the leak.
Old Feb 17, 2010 | 03:54 PM
Pure Adrenaline's Avatar
Dragging knees in
Potentially a very obvious thing, but did you check your filter?
Seen a filter so dirty and clogged that the engine kept shutting off and threw a TPS error code. True story.
If the airway is fine, then I would suspect the IACV.
Old Feb 18, 2010 | 02:59 AM
thinhthan's Avatar
no the air filter is fine ima prob try taking the iac out and cleaning it
Old Feb 18, 2010 | 06:45 PM
nsnrider's Avatar
i've never seen that but i guess something to keep in mind for reference in the future.
Old Feb 25, 2010 | 05:00 PM
B-Rad03's Avatar
I had that problem, turns out it was just a bad tank of gas I got downtown. Just added some fuel cleaner on my next tank. Never happened since.
Old Mar 10, 2010 | 07:58 AM
twill220's Avatar
sorry guys, but what is iacv? i think this may b my prob also
Old Mar 10, 2010 | 08:05 AM
chao_zu55's Avatar
hi guys, I have the same problem, if it works could someone please post some type of diy?
Old Mar 10, 2010 | 11:17 AM
kakins23's Avatar
My car has the same problem every winter it the gas....I have had it tested at Acura they even put a cpu on my car for a week to see if there were any other problems. If you call your dealer they are should have an ifnlux of vehicals with the same problem.
Old Mar 10, 2010 | 11:19 AM
kakins23's Avatar
Look up winter gas in problems and fixes
Old Mar 10, 2010 | 12:52 PM
fsttyms1's Avatar
Look in the DIY thread. there are pics of what needs to be taken off and cleaned and where its at.
Puma Jim
20
Oct 20, 2016 11:59 AM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
rockyboy
Sep 29, 2015 12:05 AM
chiu0nthls
3G MDX (2014-2020)
Sep 28, 2015 03:46 AM
prbori
Sep 27, 2015 01:37 AM
