Strange Jerking, possible trans?
Old Nov 21, 2019 | 10:28 PM
Anthony Johnson's Avatar
6th Gear
Unhappy Strange Jerking, possible trans?
Hey guys, I have heard quite a bit about the second generation transmissions and their problems which makes me think the following is a transmission problem. However, I am going to explain this to the best of my ability to see if anybody else has had the same problems.
As I drive, if I am going slow (around 30 mph) my car jerks several times as if the transmission may be slipping, but it's not all the time, just occasionally. I don't have any lights on and I do need to replace the radius rod bushings. I have heard that clogged catalytic converters, and few other things can cause jerking. Is this possible or is it more than likely the transmission? If anybody has had this happen please feel free to input.
Old Nov 22, 2019 | 02:01 AM
Jamesharoldk's Avatar
I’ve actually had the same issue and have tried everything but seem a bit lost as what is left to be done. Had some work done on my 2000 tl and it was running smooth then went back to square one. Anyone out there with any ideas..? Coils have been replaced, plugs (NGK), has new mufflers and had exhaust replaced (was running rich), cleaned MAF..
Old Nov 22, 2019 | 11:39 AM
whitetiger5's Avatar
Have you guys checked your IAC valve? if it gets stuck from carbon buildup, then it could sporadically get stuck in the open position allowing a random amount of air into your system.
it's very easy to dissemble and clean with throttle body cleaner, the difficult part is getting it off the throttle body.
Montaigne
Mar 14, 2017 10:59 PM
sparkyj
Jan 23, 2017 07:29 PM
hendricknick
1G TL Problems & Fixes
15
Jul 29, 2008 12:26 PM
Soccer_playa1579
Nov 10, 2007 10:01 AM
