Starting problem???
Old Jun 27, 2006 | 12:29 AM
asianstyle's Avatar
Starting problem???
my wife has a 2000 TL. tonight she got in and tried to crank her car and it did nothing. the lights and radio came on but the car would not crank. after a couple of tries it finally started, this has happened about 3 times already. when she turns the key it doesn't even roll over likes it trying to start. any help as to what it could be would be highly appreciated. Could it be her starter going out?
Old Jun 27, 2006 | 08:35 AM
SatinSilverTypS's Avatar
ChairmanMaoSaysRTFM
i had this problem in a 93 taurus. turned out to be corroded battery cables. the interior lights and radio and everything would turn on but the starter couldn't get sufficient juice.
first things first. check the battery voltage. if its around 11-12V you're ok.
do you hear a clicking noise from the engine when you turn the key? if so the starter and solenoid are definitely getting juice and the starter motor is likely degraded (the solenoid makes the clicking noise as it gives power to the starter motor).
if you don't hear a clicking then you may want to get under the car with a voltmeter and check the solenoid terminals to see if it's getting voltage from the battery. if it's not then the battery cables are suspect.
if it *is* getting power but not cranking the engine then the starter likely needs replacing.
did i make sense or confuse you more?
SSTS
Old Jun 27, 2006 | 02:58 PM
Bob_F's Avatar
Excellent suggestions by SSTS.
A faulty ignition switch could also be a possibility.
Bob
Old Jun 27, 2006 | 03:12 PM
Tanginaglaz's Avatar
Certified Rageaholic
Had this same problem. It could be your starter. I just hit my starter with a hammer and took it to a shop to get the starter changed. Don't hit the starter that hard tho...
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
obert
Dec 14, 2015 11:36 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
jordanboi
Sep 5, 2015 01:33 AM
NSolace
Sep 3, 2015 08:02 PM
