start up issue
start up issue
everytime i start up my car weather its hot or cold ive noticed that it takes a long time to start. dont get me wrong it starts up every single time but i feel as if it just does a little bit of extra cranking than normal before it starts. what could be the problem? i just changed my plugs with new oem spark plugs. my battery is good but who knows the last time its been changed. im guessing it has to do something with either the coils or battery. any help is appreciated. 02 TL-S 65k
Describe what is a long time? 5sec, 10 sec????
yes maybe 4 or 5 seconds it takes to start... it might not sound like its too long but 4 or 5 seconds to start a car is excessive, i highly doubt its normal i mean every car ive ever owned started right up in under two seconds.
thats the same thing im thinking but i wouldnt say its bad because the car starts everytime ive never had to jump start it or anything so the battery isnt completely bad but i guess its just old so im just gonna get a new one and see if that helps. thanks
could be as simple as a loose connection to the battery..start there.
Just because it starts doesnt mean the battery is good. It its aging the CCA voltage may not be there resulting in slightly longer start up time. Others have had the same issue and the battery was the problem. Try cleaning the battery terminals like stated above. Have your battery load tested.
2003 TL-p
put a dmm across the batt terms, and have some one watch the voltage drop as you crank, then tell us how much the voltage dropped. (easy way to load test)
WNC Real Estate Sales99TL
Mine did the same thing till I replaced the battery. Go to an Auto parts store or garage and have your battery checked. The new battery made a world of difference.
when did the problem start? if its not too long ago than i'd guess the battery.. u'll notice it'll take longer and longer to start than 1 day its just not gonna start anymore...
I changed mine about 2 yrs ago, and now it starts like a charm.
i bought the car about a month ago and ever since i bought it its been starting up like this.... yesterday i went to autozone and bought a brand new duralast gold battery for the car and installed it and i still have the same problem it doesnt start right away. what a waste of 100 bucks but the again i guess we can count the battery out now.
![Annoyed](https://acurazine.com/forums/images/smilies/annoyed.gif)
i bought the car about a month ago and ever since i bought it its been starting up like this.... yesterday i went to autozone and bought a brand new duralast gold battery for the car and installed it and i still have the same problem it doesnt start right away. what a waste of 100 bucks but the again i guess we can count the battery out now. ![Annoyed](https://acurazine.com/forums/images/smilies/annoyed.gif)
did you ever get it fixed? i think i'm having the same issue
2003 TL-S w/Navi NBP
new ngk plugs wont make it hard to start-unless someone sold him the wrong plugs! has happened before,,oh yeah these are stock~
always get parts like battery tested for free before replacement when tracking a problem
You could have weak battery cable(s) they are getting pretty old now
I would run cleaner like seafoam or redline SI-1 thru half tank of gas with full bottle of cleaner- get a baseline of clean to start diagnosis if problem exist after cleaning
If the injectors are dirty the spray pattern goes crazy
Then seafoam or bd or wynns (not to play favorites) the intake manifold via the master vac port- that cleans the intake valves and pistons
Next would be pull the intake manifold and clean the EGR ports- they plug up solid at 75kmiles
cycdaniel
12-17-2019 10:58 AM
