squeeling brakes
squeeling brakes
just changed front rotors/brakes and rear as well. went with Rotora rotors/Axxis pads and installed them about 3 days ago. Problem is they still squeel when i brake and its annoying......is this normal....any soloutions.
And you may need to do the brake pad break in procedure
Its usually good to get several normal heat and cool cyles on the rotors
then do the bedding in procedure
Enjoy your newfound stopping power!
Moderator Alumnus
i know about the bedding procedure....how do i break the pads in? how long does this take
squeeling brakes
can someone please help me on this....I recently bought rotora rotors and axxis break pads all around, and 2 months later when i brake they are still squeeling. I have taken them twice to the shop and cannot figure it out. I have put an anti-squeel paste, bedded the brakes twice, and still no solution. Starting to feel like its maybe the brake pads itself.
Axxis suck (IMHO). Also did you use the paste or the grease? shims or no shims? Did you grease the contact points where the pads touch the caliper
GWEEDOspeedo
01-15-2016 10:39 PM
lanechanger
10-13-2015 10:56 AM
