squeeling brakes
Old Feb 3, 2007 | 04:55 AM
g$tl's Avatar
9th Gear
squeeling brakes
just changed front rotors/brakes and rear as well. went with Rotora rotors/Axxis pads and installed them about 3 days ago. Problem is they still squeel when i brake and its annoying......is this normal....any soloutions.
Old Feb 3, 2007 | 07:45 AM
torez's Avatar
Take the pads off. Put some antisqueel paste (you can pick this up in any auto store) in the back of the pads and... you are good to go!
Old Feb 3, 2007 | 08:28 AM
djdonte's Avatar
Old Feb 4, 2007 | 04:41 PM
g$tl's Avatar
9th Gear
thanks for your feeback......will try it tommorow.
Old Feb 4, 2007 | 05:22 PM
01tl4tl's Avatar
And you may need to do the brake pad break in procedure
Its usually good to get several normal heat and cool cyles on the rotors
then do the bedding in procedure
Enjoy your newfound stopping power!
Old Feb 5, 2007 | 12:24 AM
g$tl's Avatar
9th Gear
i know about the bedding procedure....how do i break the pads in? how long does this take
Old Feb 5, 2007 | 01:59 AM
Lawaia's Avatar
Moderator Alumnus
Bedding procedure is breaking in (seasoning) the rotor.
Old May 21, 2007 | 08:24 PM
g$tl's Avatar
9th Gear
Exclamation squeeling brakes
can someone please help me on this....I recently bought rotora rotors and axxis break pads all around, and 2 months later when i brake they are still squeeling. I have taken them twice to the shop and cannot figure it out. I have put an anti-squeel paste, bedded the brakes twice, and still no solution. Starting to feel like its maybe the brake pads itself.
Old May 21, 2007 | 08:25 PM
g$tl's Avatar
9th Gear
2 Months Later Guys And Still Squeeling, Dont Know What Else To Do.......
Old May 21, 2007 | 09:29 PM
fsttyms1's Avatar
Axxis suck (IMHO). Also did you use the paste or the grease? shims or no shims? Did you grease the contact points where the pads touch the caliper
Old May 23, 2007 | 10:54 PM
g$tl's Avatar
9th Gear
paste andyeah i did actually, so pissed at axxis i think iam going to have to change the break pads.
GWEEDOspeedo
Jan 15, 2016 10:39 PM
lanechanger
Oct 13, 2015 10:56 AM
rockyboy
Oct 2, 2015 10:45 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
2ManyHobbies
Sep 24, 2015 09:23 PM
