squeeky rear end
Old Mar 29, 2009 | 11:05 AM
MurdaZ's Avatar
squeeky rear end
well recently started squeeking, but i know its the rear sway bushing, u can see the seperation from the bushing/sway...question is, what kind of grease can i use? gonna try greasing it first, then buy new bushings if needed.
Old Mar 29, 2009 | 12:16 PM
fsttyms1's Avatar
Any grease will work. Some use Teflon tape.
Old Mar 30, 2009 | 02:12 AM
Edward'TLS's Avatar
6G TLX-S
Keep the urethane bushings well lubricated, and there will be no more rear sway bar squeaks.
Old Mar 30, 2009 | 09:33 AM
phee's Avatar
I got the Shifts
try a laxative.
just kidding. lubricate the bushings
Old Mar 30, 2009 | 01:29 PM
Bearcat94's Avatar
AZ Community Team
Look into the Black, graphite impregnated bushings. I changed from Energy Suspension (Red) greasable bushings to the Black and my little RSB squeak disappeared.
Old Mar 30, 2009 | 04:52 PM
MurdaZ's Avatar
cool, thansk guys, will attack it this weekend.
Old Mar 31, 2009 | 01:51 PM
digitalextremes's Avatar
02 TL Type-S
In my case it was the trunk, the latch came up a little bit for some reason, one small hit with a hammer on the latch where the trunk locks to, fixed the issue, try moving your trunk up and down...worth checking if you hear noice from the rear while driving.
Old Mar 31, 2009 | 05:31 PM
TLer trash's Avatar
I think you're better off replacing the bushings, especially if you can see clearance between the bushing and the bar. The lube will quiet the squeak temporarily, but the clunk will soon follow. Urethane bushings require occasional lube, but most factory rubber ones are designed to grab the bar and twist with it. For this reason lubing most oe rubber bushings is not recommended, and can cause more wear.
Feb 25, 2020 09:57 AM
wilztlxs
Dec 1, 2015 09:16 AM
Sep 15, 2015 06:44 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
