squeaky brakes
Old Dec 3, 2011 | 07:34 AM
FrankWhizzite's Avatar
squeaky brakes
i had recently changed my front brake pads and rotors, now the are squeaking very loud and high pitched at low speed. i checked the rear pads and they seem to be ok. anybody have any reasons this could be happening or products to stop the squeak as it is very annoying and confusing since they are brand new.
Old Dec 3, 2011 | 11:59 AM
01tl4tl's Avatar
what brand parts did you use
did you bed the pads in ? thats wearing the pads and rotors into each other so all the micro hills and valleys meet for full contact, then doing a hot transfer of pad material to rotor,,makes them work better, last longer and stay quiet
noise can often be from using the brakes too gently and causing a glaze to form
did you clean and relube all the slider parts and pins? torque is correct on every bolt?
Old Dec 3, 2011 | 12:01 PM
01tl4tl's Avatar
do NOT use products that spray on to hide noise! find out whats up
did you transfer the backing plate/spacers on the pads, or the new ones came with them installed?
Old Dec 6, 2011 | 05:47 PM
I do not recall the brand of parts. i got them from a website i use all the time called am-autoparts.com. i guess i did bed them, they came with new back plates, and i did clean but did not relube them.
GWEEDOspeedo
Jan 15, 2016 10:39 PM
lanechanger
Oct 13, 2015 10:56 AM
rockyboy
Oct 2, 2015 10:45 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
2ManyHobbies
Sep 24, 2015 09:23 PM
