Speedometer HELP!
Old Oct 25, 2005 | 01:01 PM
Tanginaglaz's Avatar
Certified Rageaholic
Speedometer HELP!
I accidentally pulled out the speedometer when i was messing around with the reverse glow gauges. Now i suspect its a little off. I stuck it back on with the engine on in which it should be at zero. However it seems like its about 10 mph off. Anyone know how i can fix this? Any help is welcome, thanx.
Old Oct 25, 2005 | 02:45 PM
fsttyms1's Avatar
well the best way i know if is with the clear cover off and a friend who has a accurate spedo drive next to him at a steady speed (like 30) and set the cruise. then procede to stick the needle on (i had to do this)
Old Oct 25, 2005 | 03:04 PM
SatinSilverTypS's Avatar
ChairmanMaoSaysRTFM
if fsstyms1's procedure works for you then you're lucky. i messed up my friend's tachometer needle in his prelude and i found out that there was no way in hell to put it back in accurately. good luck. if worse comes to worse you can buy a used gauge cluster and swap out the speedo. as long as you *know* it's about 10mph off you can luckily compensate for it.
SSTS
Old Oct 25, 2005 | 04:39 PM
Pure Adrenaline's Avatar
Dragging knees in
That's probably the best way to do it.
Another way to do it is to put the car on a dyno; it will give accurate speed readings (provided you put in the correct gear ratios, of course). Hold it at a constant speed and stick it back on. But this will cost probably anywhere from 50-100 bucks.
Old Oct 25, 2005 | 04:46 PM
Dragging knees in
Can't edit after 5 minutes, bah.
I just wanted to correct myself -- you won't have to have the gear ratios; you mainly need that for proper torque readings... for a speed reading, it's taken directly from the dyno itself.
cycdaniel
Dec 17, 2019 10:58 AM
pstomps
1G CL Tires, Wheels, & Suspension
Oct 18, 2015 07:48 PM
Retep Nitciaj
1G RL (1996-2004)
Oct 6, 2015 01:38 PM
Retep Nitciaj
1G RL (1996-2004)
Oct 6, 2015 01:36 PM
Sep 17, 2015 08:57 PM
